JLG 1932R won't drive
benvr
33
We've got one of these in the corner of our shop that no one has touched in a while. Everything turns on and powers up. The platform will go up and down. But I can't get it to drive... The control panel is covered in caked on paint so I can't really see what's what. But I feel like I've tried every combination or button controls.
Everything looks to be functional... connections are tight, hydraulic fluid is good etc...
Any Ideas?
My usual walk through process...
Safety Switches: First thing's first, check if the safety interlocks are engaged. These lifts have sensors that prevent driving when the platform is raised too high. Lower the platform completely and try again.
Enable Switch: There's usually a foot switch or a hand-operated enable switch that needs to be engaged before the drive function works. Make sure you're activating this while trying to drive. Sometimes it'll move but the connection is broken so this could be an issue.
Drive/Lift Selector: Some models have a switch to select between drive and lift functions. Make sure it's set to drive.
Emergency Stop Button: Check if the E-stop button is fully released on both the platform and ground controls.
Battery Charge: Even though it powers up, the batteries might not have enough juice for the drive motors. Try charging it overnight.
Brake Release: The manual brake release might be engaged. Look for a knob or lever near the drive wheels and make sure it's in the normal position.
Control Panel: That caked-on paint could be your culprit. Clean it off carefully - you might be missing a crucial switch or indicator.
Beyond that, if you're not seeing any error codes you might need to bring a tech out.
Good thing is, that's not a big unit so I imagine you've got something else capable of towing in out the corner if needed.
I feel like an idiot...
After spending a bulk of the moment looking for an answer, an old head came over, lifted the platform 2 feet, and then it drove. It had to be LIFTED a bit to drive... which seems counterintuitive to me, wouldn't it be safer to require it to be all the way down?
Haha, no worries @benvr, we've all been there! Sometimes the simplest fixes are the most frustrating. And yeah, that does seem a bit backwards, maybe it's a built-in safety feature for certain conditions? Either way, at least you didn’t have to tear the whole thing apart to figure it out! Anyone else run into weird quirks like this on lifts?
Glad you got it figured out, @benvr! It's always the little things, right? I’ve definitely run into some weird quirks with lifts before, like one that refused to go up unless it was perfectly level. Who knew they were so picky?
