9 Min read
August 17, 2026
Demolition and recycling attachments turn excavators, skid steers, wheel loaders, and other heavy equipment into versatile tools for breaking concrete, processing scrap, sorting debris, pulverizing structures, and recycling construction materials.
Choosing the right attachment depends on the material, machine size, jobsite conditions, required production rate, and type of demolition or recycling work. This guide explains the most common attachments, what they do, how they compare, and what to consider before buying or renting.
Demolition and recycling attachments are tools mounted to heavy equipment to break, cut, crush, sort, handle, and process materials during demolition and recycling projects.
Browse all equipment
A hydraulic breaker is commonly used to break concrete, asphalt, and rock. Concrete pulverizers are better suited for crushing and processing concrete after primary demolition.
Demolition shears are hydraulic attachments designed to cut structural steel, pipe, tanks, and other metal materials during demolition and scrap processing.
A hydraulic breaker uses impact energy to fracture hard materials, while a pulverizer uses crushing jaws to reduce concrete into smaller pieces and help separate reinforcing steel.
A grapple is commonly used to grab, move, load, and sort demolition debris such as concrete, wood, scrap metal, and mixed materials.
Choose a demolition attachment based on the material, required task, carrier machine, hydraulic flow and pressure, attachment weight, production requirements, and jobsite conditions.
We recommend evaluating attachments based on:
Carrier compatibility
Hydraulic requirements
Material type
Attachment capacity
Productivity
Durability
Maintenance
Safety
Attachment weight
Manufacturer support
New vs. used condition
The right attachment depends on what needs to be demolished and processed.
Also called hydraulic hammers, breakers use hydraulic energy to fracture concrete, asphalt, rock, and other hard materials.
Best for: Concrete demolition, rock breaking, trenching, and roadwork.
Shears use powerful jaws to cut through steel and other structural materials.
Best for: Structural demolition and scrap-metal processing.
Pulverizers crush concrete and can help separate concrete from reinforcing steel.
Best for: Secondary concrete demolition and recycling.
Grapples are used to grab, sort, load, and move demolition debris.
Best for: Material handling, sorting, and cleanup.
Crusher buckets process material directly using the carrier machine.
Best for: On-site recycling and reducing material volume.
Screening buckets separate materials based on particle size.
Best for: Soil screening, aggregate processing, and material separation.
A hydraulic breaker is one of the most common demolition attachments.
It uses hydraulic pressure from the carrier machine to drive a piston against a tool bit, creating impact energy.
Breakers are available in different sizes for:
Mini excavators
Compact excavators
Skid steers
Mid-size excavators
Large excavators
Use a breaker when you need to fracture hard material rather than cut or grab it.
Common applications include:
Breaking slabs
Demolishing foundations
Removing pavement
Breaking rock
Trenching through hard material
Concrete pulverizers use crushing jaws to reduce reinforced or unreinforced concrete into smaller pieces.
They can also help expose reinforcing steel, making material separation easier.
Best for: Processing concrete after primary demolition.
A breaker primarily fractures material through impact, while a pulverizer crushes material through jaw movement.
For many demolition projects, both tools can have a role.
Demolition shears are designed to cut structural steel, pipe, tanks, and other metal components.
They are commonly used for:
Building demolition
Industrial dismantling
Scrap processing
Steel recycling
Cutting structural members
When selecting a shear, consider the carrier's hydraulic flow, operating weight, attachment weight, and required cutting capacity.
A demolition grapple provides a powerful way to grab, move, load, and sort materials.
Depending on the design, grapples can handle:
Concrete
Wood
Scrap metal
Brush
Mixed debris
Grapples can improve material handling after demolition and help separate recyclable materials before processing.
A crusher bucket mounts directly to compatible excavators or other carriers and processes material at the jobsite.
This can reduce the need to transport some demolition material away for initial processing.
Potential benefits include:
Reduced material hauling
On-site processing
Smaller material size
Reuse of suitable aggregate
Always verify that the carrier has sufficient hydraulic capability and lifting capacity for the specific crusher bucket.
Screening buckets use rotating or specialized screening components to separate materials by size.
They can process:
Soil
Aggregate
Compost
Demolition material
Reclaimed material
Best for: Separating usable material from unwanted debris and preparing material for reuse.
Magnetic attachments use magnetic force to collect ferrous metals from demolition debris.
They can help recover:
Steel
Iron
Reinforcing bar
Scrap metal
Magnets are particularly useful when recovering metal from large demolition sites.
Before purchasing an attachment, verify compatibility with the carrier machine.
Important specifications include:
Operating weight
Hydraulic flow
Hydraulic pressure
Mounting system
Auxiliary hydraulic connections
Machine lift capacity
Attachment weight
Recommended carrier size
An attachment should never be selected based solely on whether it physically fits the machine.
Excavators are among the most versatile carriers for demolition attachments.
Depending on the model and configuration, an excavator can operate:
Breakers
Pulverizers
Shears
Grapples
Magnets
Crusher buckets
Screening buckets
Large excavators are generally suited to heavier attachments, while compact excavators can handle smaller demolition and renovation projects.
Skid steers and compact track loaders can operate numerous attachments, making them useful for smaller demolition and recycling jobs.
Common options include:
Hydraulic breakers
Grapples
Buckets
Brush cutters
Screening attachments
Material-handling tools
Compact dimensions make these carriers particularly useful when working in confined spaces.
Wheel loaders are especially useful for moving and loading processed material.
Depending on the configuration, they can work with:
Grapples
Buckets
Forks
Material-handling attachments
Specialized recycling tools
They are particularly effective when high-volume material movement is required.
Start by identifying the material and task.
Is it:
Concrete?
Steel?
Asphalt?
Wood?
Mixed debris?
Soil?
Rock?
Do you need to:
Break?
Cut?
Crush?
Sort?
Screen?
Lift?
Move?
Check the carrier's:
Hydraulic flow
Pressure
Operating weight
Lift capacity
Auxiliary circuits
Determine how much material must be processed per hour or day.
Large attachments may significantly affect transportation requirements.
Attachment size should match the carrier.
A general relationship is:
Small carrier Smaller attachment
Large carrier Larger attachment
But manufacturer specifications should always determine compatibility.
For example, a breaker designed for a 20-ton excavator should not automatically be installed on a smaller machine simply because the mounting connection appears compatible.
Hydraulic attachments depend on the carrier's auxiliary hydraulic system.
Two key specifications are:
Usually measured in gallons per minute (GPM) or liters per minute (L/min).
Usually measured in psi or bar.
The attachment must operate within the manufacturer's specified hydraulic range.
Too little flow can reduce performance, while excessive flow or pressure can damage components.
Demolition can involve two stages.
The goal is to bring down or break apart the main structure.
Common attachments:
Hydraulic breakers
Shears
Large demolition tools
The goal is to process and separate the resulting debris.
Common attachments:
Pulverizers
Grapples
Magnets
Screening buckets
Understanding this distinction helps contractors select the right tools for each stage.
Operators should:
Follow the attachment manufacturer's instructions.
Confirm carrier compatibility.
Inspect hydraulic lines and connections.
Keep workers outside exclusion zones.
Wear appropriate PPE.
Check for overhead and underground hazards.
Follow site-specific demolition procedures.
Never exceed rated capacities.
Demolition work can involve falling debris, flying material, hydraulic hazards, structural instability, and unexpected movement.
Regular inspection can help identify problems before they cause downtime.
Check:
Hydraulic hoses
Pins and bushings
Jaw condition
Cutting edges
Wear plates
Grease points
Bolts and fasteners
Hydraulic connections
Cracks
Mounting components
Follow the manufacturer's maintenance schedule for lubrication, wear limits, and replacement components.
Inspect hoses, fittings, seals, and connections.
Possible causes include incorrect hydraulic flow, pressure issues, worn components, or carrier problems.
Using the wrong attachment for the material or carrier can accelerate wear.
Overloading, improper use, or fatigue can damage attachment structures.
Poor Crushing Performance
Check hydraulic settings, material characteristics, jaw condition, and carrier compatibility.
Advantages:
Manufacturer warranty
Latest designs
Known operating history
New wear components
Advantages:
Lower upfront cost
Potentially strong value
Access to professional-grade equipment
When inspecting used attachments, check:
Wear
Cracks
Hydraulic cylinders
Pins and bushings
Hoses
Mounting bracket
Cutting edges
Jaw condition
Service history
Prices vary significantly based on:
Attachment type
Size
Carrier class
Brand
Capacity
Condition
Included mounting hardware
A small hydraulic breaker can cost substantially less than a large demolition shear or industrial crusher.
For a buying guide, organize prices by attachment category and update them regularly.
Attachments can provide substantially more productivity than handheld demolition tools on larger projects.
The right tool depends on project size and material.
Recycling attachments can help contractors process suitable materials closer to the point of demolition.
Reduced hauling
Material reuse
Reduced waste
On-site processing
Recovery of recyclable metals
However, environmental benefits depend on the material, project logistics, processing requirements, and local regulations.
Demolition attachments are tools mounted to excavators, loaders, skid steers, and other machines to break, cut, crush, sort, and move demolition materials.
A hydraulic breaker is commonly used to break concrete, asphalt, and rock. A pulverizer is generally better suited to secondary concrete processing.
Demolition shears are designed to cut structural steel and other metal materials.
Concrete pulverizers and crusher buckets can crush and process concrete, depending on the machine and application.
A grapple is commonly used to grab, move, and sort mixed demolition materials.
Yes. Skid steers and compact track loaders can operate compatible demolition attachments such as hydraulic breakers and grapples.
Check the attachment manufacturer's requirements for carrier weight, hydraulic flow, hydraulic pressure, mounting configuration, and lifting capacity.
The best demolition or recycling attachment depends on what material you need to process, what task you need to perform, and which carrier machine you have.
Choose a breaker for hard materials, shear for steel, pulverizer for concrete, grapple for debris handling, and crusher or screening attachments for on-site material processing.
Before buying, verify hydraulic requirements, attachment weight, carrier compatibility, production needs, maintenance requirements, and safety considerations.
Looking for the right heavy equipment or attachment? Compare available machines and attachments based on condition, specifications, application, and total operating requirements.
