October 5, 2026
Heating and cooling equipment helps maintain suitable temperatures and working conditions in residential, commercial, industrial, and construction environments. Common equipment includes heaters, air conditioners, heat pumps, chillers, boilers, and portable climate-control units.
The right equipment depends on the size of the space, required heating or cooling capacity, operating environment, available power or fuel, ventilation requirements, and intended application.
Heating and cooling equipment is designed to raise, lower, or maintain indoor and enclosed-space temperatures. Some systems provide heating or cooling separately, while others, such as heat pumps, can provide both.
Browse all equipment
For construction and industrial applications, equipment may be permanent or portable. Portable units can provide temporary temperature control during construction, maintenance, seasonal work, or other projects.
Portable heaters provide temporary or localized heat and are commonly used on construction sites, workshops, warehouses, and other spaces requiring supplemental heating.
Fuel sources can include electricity, propane, natural gas, or other approved fuels. Fuel-fired heaters require appropriate ventilation and installation clearances.
Forced-air heaters use a fan to distribute heated air through a space. They can quickly raise temperatures in large or partially enclosed areas and are commonly used for temporary heating applications.
Radiant heaters transfer heat directly to people, surfaces, and objects rather than relying primarily on heating the surrounding air. They can be useful for localized heating in large or open spaces.
Electric heaters convert electrical energy into heat and are available in portable and fixed configurations. They can be useful where electrical power is available and combustion-based equipment is unsuitable.
Boilers heat water or another fluid that is circulated through pipes to provide heat through radiators, radiant systems, air-handling equipment, or other heat-transfer devices.
Portable air conditioners provide localized cooling and can be useful where permanent air-conditioning systems are unavailable or impractical.
Air-conditioning equipment removes heat from indoor air and transfers it outside. Systems may include packaged units, split systems, or other configurations depending on the application.
Evaporative coolers reduce air temperature by using water evaporation. Their effectiveness depends heavily on climate and humidity conditions.
Chillers remove heat from water or another circulating fluid. They are commonly used in larger commercial and industrial cooling systems and can supply chilled water to air-handling or process equipment.
Heat pumps transfer heat rather than simply generating it. Depending on the system, they can provide both heating and cooling by reversing the direction of heat transfer.
The best choice depends on the application, space, climate, available utilities, required capacity, and operating conditions.
Construction and industrial environments can have different climate-control requirements from residential buildings.
Temporary heating may be required during cold-weather construction, equipment maintenance, concrete-related work, or work in enclosed structures. Cooling equipment can help manage heat in enclosed workspaces and provide more suitable conditions for workers and equipment.
OSHA requires appropriate ventilation when temporary heaters are used in confined spaces and specifies clearance and installation requirements for certain temporary heating devices.
For workplace heat management, OSHA also distinguishes air cooling from ventilation: air conditioning removes heat from air, while ventilation primarily moves or replaces air.
When comparing equipment, consider more than the purchase price.
Important specifications can include:
Heating or cooling capacity
BTU/h or other capacity ratings
Electrical requirements
Fuel type
Airflow
Operating temperature range
Coverage area
Refrigerant type where applicable
Energy-efficiency ratings
Noise level
Operating weight
Dimensions
Portability
Ventilation requirements
Exhaust requirements
Control systems
Maintenance requirements
Always compare specifications using the manufacturer's documentation and the exact model and configuration.
Start by identifying the environment and the job requirements.
Decide whether the equipment is needed for construction, industrial production, warehouse operations, temporary workspaces, maintenance, or another application.
Select equipment based on the size and characteristics of the space rather than choosing solely by physical size or price. Proper sizing is important because oversized or undersized equipment can affect comfort, operating costs, and performance.
Determine whether the site has the required electrical service, fuel supply, ventilation, and connections.
Evaluate temperature, humidity, dust, ventilation, enclosure, outdoor exposure, and available space.
For temporary projects, wheels, lifting points, compact dimensions, and transportation requirements may be important.
Consider fuel or electricity consumption, maintenance, replacement parts, transportation, and expected service life.
Check manufacturer instructions and applicable workplace regulations before operating heating or cooling equipment.
Used equipment can provide a lower initial purchase cost, but condition and maintenance history are critical.
Before buying used heating or cooling equipment, review:
Manufacturer and model
Model year
Operating hours
Capacity
Previous application
Maintenance records
Repair history
Fuel or power requirements
Included accessories
Operating condition
Availability of replacement parts
Compare the equipment's age and operating hours with its service history. A machine with documented maintenance can be a stronger purchase candidate than equipment with fewer hours but an unknown history.
Inspect used equipment before purchasing, especially when the equipment will be used continuously or in demanding environments.
Check the frame, housing, panels, wheels, handles, mounts, and signs of corrosion or physical damage.
Inspect burners, heat exchangers, fuel lines, controls, fans, electrical connections, and safety controls where applicable.
Check compressors, coils, fans, refrigerant-related components, hoses, drains, and controls.
Test switches, controls, wiring, displays, breakers, motors, and other electrical components.
Check fans, filters, duct connections, vents, and exhaust components.
Verify guards, shutdown systems, alarms, protective devices, and other safety features.
Review service records, previous repairs, replacement components, and evidence of routine maintenance.
When safe and appropriate, operate the equipment long enough to identify unusual noises, leaks, vibration, overheating, poor airflow, or inconsistent temperature control.
For used heavy equipment, Boom & Bucket inspection reports can include checks of systems such as the air conditioner, heater, engine, cooling system, drivetrain, hydraulics, electrical components, and safety equipment.
Regular maintenance can help maintain equipment performance and identify problems before they become expensive repairs.
Common maintenance tasks include:
Cleaning or replacing filters
Inspecting electrical connections
Checking hoses and fittings
Inspecting fans and motors
Checking fuel systems
Cleaning coils and heat-transfer surfaces
Inspecting drains
Checking controls and safety devices
Following manufacturer service intervals
Safety is particularly important with fuel-fired heating equipment. OSHA requires adequate fresh air and ventilation in certain applications and specifies clearance requirements for temporary heating devices.
Always follow the manufacturer's operating instructions and applicable regulations.
Choosing heating and cooling equipment requires evaluating capacity, operating environment, power or fuel requirements, ventilation, portability, maintenance needs, and total operating costs. For used equipment, buyers should also review operating hours, service history, previous applications, and overall condition.
Common types include portable heaters, forced-air heaters, radiant heaters, electric heaters, furnaces, boilers, and heat pumps.
Common cooling equipment includes air conditioners, portable cooling units, evaporative coolers, chillers, and heat pumps.
HVAC stands for heating, ventilation, and air conditioning. HVAC equipment controls temperature and may also support ventilation, humidity control, and indoor air quality.
Consider the application, space size, required capacity, climate, power or fuel availability, ventilation, portability, operating costs, and maintenance requirements.
Used equipment can be a practical option when its capacity, condition, maintenance history, and operating requirements match the intended application. A thorough inspection is recommended.
Check the overall condition, capacity, engine or compressor, electrical system, fans, controls, cooling or heating components, safety systems, operating hours, and maintenance records.
Maintenance intervals vary by equipment type and manufacturer. Follow the service schedule for the specific model and inspect critical components regularly.
Ready to find equipment for your next project? Compare used equipment by type, model, specifications, operating hours, condition, and price.
Explore Boom & Bucket's used equipment inventory to find machines and equipment that match your project requirements and budget.
Choosing the right heating and cooling equipment starts with understanding your application, required capacity, operating environment, and budget. Whether buying new or used, compare specifications, condition, maintenance history, safety requirements, and total ownership costs to find equipment that fits your project.
Albert Demi is an Account Manager at Boom & Bucket, managing high-value construction and heavy equipment accounts with a focus on retention, growth, and tailored equipment solutions. With a strong background in sales leadership and partnerships, Albert is known for exceeding revenue targets, maintaining exceptional renewal rates, and building long-term client relationships through proactive support and industry insight.
