11 Min read
November 30, 2026
Industrial facilities rely on the right equipment to keep production moving, materials flowing, and daily operations running efficiently. From pumps and compressors to conveyors, boilers, generators, and processing machinery, every piece of equipment plays a role in keeping a plant productive.
However, choosing industrial plant equipment involves more than comparing machine sizes or purchase prices. Businesses must consider production requirements, operating conditions, energy consumption, maintenance needs, safety standards, and long-term operating costs.
This guide explains the main types of industrial plant equipment, their uses, and what to consider when purchasing or maintaining machinery.
Industrial plant equipment refers to the machines, systems, and supporting machinery used in manufacturing, processing, power generation, material handling, and other industrial operations.
Browse all Skid steers
These assets help facilities transform raw materials into finished products, move materials between production stages, control operating conditions, and provide essential utilities.
Depending on the industry, industrial plant equipment may include:
Production and processing machinery
Pumps and compressors
Conveyors and material handling systems
Boilers and heat exchangers
Generators and electrical equipment
Cooling and ventilation systems
Storage tanks and pressure vessels
Water treatment and filtration systems
Each facility has different requirements. A food processing plant, for example, may depend on mixers, refrigeration systems, and packaging machinery, while a chemical processing facility may require pumps, reactors, tanks, and specialized separation equipment.
Industrial plants use different equipment depending on their products, processes, and production capacity. The following categories cover many of the machines and systems found in industrial facilities.
Pumps move liquids through pipes, tanks, and processing systems. They are commonly used in water treatment, chemical processing, manufacturing, and industrial cooling.
Common types include:
Centrifugal pumps
Positive displacement pumps
Diaphragm pumps
Submersible pumps
Gear pumps
When selecting a pump, consider the required flow rate, pressure, liquid properties, operating temperature, and material compatibility.
Compressors increase the pressure of air or gas for industrial applications. Compressed air can power pneumatic tools, operate control systems, support production equipment, and assist with material handling.
Common compressor types include:
Rotary screw compressors
Reciprocating compressors
Centrifugal compressors
Scroll compressors
The right compressor depends on air demand, operating pressure, duty cycle, air quality requirements, and energy efficiency.
Conveyors transport materials from one production stage to another. They reduce manual handling and help maintain a consistent flow of materials throughout a facility.
Common conveyor systems include:
Belt conveyors
Roller conveyors
Screw conveyors
Chain conveyors
Bucket elevators
Conveyor selection depends on material weight, size, shape, distance, operating environment, and required production capacity.
Boilers generate steam or hot water for heating, processing, cleaning, and other industrial applications.
They are commonly used in food production, chemical processing, textile manufacturing, and power generation.
Industrial heating equipment may also include:
Industrial furnaces
Kilns
Dryers
Thermal oil heaters
Heat recovery systems
Important selection factors include heating capacity, operating pressure, fuel source, energy efficiency, and applicable safety requirements.
Reliable electricity is essential for most industrial operations. Generators provide backup or independent power, while electrical distribution systems deliver electricity to machinery and facility equipment.
Common equipment includes:
Diesel generators
Gas generators
Transformers
Switchgear
Distribution panels
Circuit breakers
When choosing a generator, assess the facility's total electrical load, starting requirements, backup duration, fuel availability, and operating environment.
Cooling systems remove excess heat from machinery, production processes, and facility environments. Proper temperature control helps protect equipment and maintain product quality.
Common cooling equipment includes:
Industrial chillers
Cooling towers
Air-cooled condensers
Refrigeration compressors
Heat exchangers
Industrial ventilation systems
The cooling system should match the required heat load, operating temperature, ambient conditions, and process requirements.
Processing machinery performs the main operations that transform raw materials into products. The specific equipment varies significantly between industries.
Examples include:
Industrial mixers and blenders
Crushers and mills
Extruders
Reactors
Centrifuges
Filtration systems
Packaging machines
The best equipment depends on the material being processed, production volume, product specifications, and required level of automation.
Material handling equipment moves, lifts, stores, and positions materials within a facility. It supports warehouse operations, manufacturing lines, loading areas, and industrial construction.
Common examples include:
Overhead cranes
Hoists
Pallet trucks
Industrial loaders
Automated guided vehicles
Before selecting lifting equipment, check load capacity, lifting height, travel distance, floor conditions, available space, and operator requirements.
Storage tanks hold liquids, gases, and bulk materials for production and distribution. Pressure vessels are designed to contain fluids at pressures different from the surrounding environment.
Applications include water storage, fuel storage, chemical processing, compressed gas systems, and industrial heating.
Selection considerations include:
Required storage volume
Operating pressure and temperature
Material compatibility
Corrosion resistance
Applicable design and inspection requirements
Always ensure that tanks and pressure vessels are suitable for their intended service and comply with applicable regulations.
Water treatment systems help industrial facilities manage process water, remove contaminants, and treat wastewater before reuse or discharge.
Industrial filters
Reverse osmosis systems
Water softeners
Clarifiers
Chemical dosing systems
Wastewater treatment units
The appropriate system depends on water quality, flow requirements, contaminants, treatment objectives, and local environmental regulations.
Industrial equipment supports nearly every stage of plant operations. Choosing suitable machinery can help businesses improve productivity, control operating expenses, and maintain consistent production.
Here are some of its main benefits.
Well-matched equipment helps maintain consistent production rates and reduces unnecessary delays. Automated systems can also perform repetitive tasks with greater consistency.
Equipment designed for specific production requirements helps maintain accurate processing conditions, measurements, and product specifications.
Conveyors, cranes, forklifts, and automated systems reduce the need for employees to move heavy materials manually. This can improve workflow and reduce certain workplace risks.
Properly selected and maintained equipment is less likely to experience avoidable breakdowns. Planned maintenance also helps identify potential problems before they interrupt production.
Efficient motors, pumps, compressors, and heating systems can help reduce energy and resource consumption when correctly sized and operated.
Selecting industrial machinery requires a clear understanding of the facility's operating requirements. Before making a purchase, evaluate these important factors.
Start by identifying what the equipment needs to accomplish.
Consider:
Required production capacity
Materials being processed
Operating hours per day
Required output quality
Current and future production demands
Avoid purchasing equipment based only on its maximum advertised capacity. The machine must perform reliably under your actual operating conditions.
Review the manufacturer's technical documentation before making a decision.
Depending on the equipment, important specifications may include:
Rated capacity
Power requirements
Flow rate and operating pressure
Temperature range
Dimensions and weight
Operating speed
Compare specifications using the same measurement units and operating conditions. A higher-rated machine is not automatically the best choice for every facility.
Industrial machinery needs enough space for installation, operation, inspection, and maintenance.
Check the facility layout, access routes, foundations, electrical connections, ventilation, piping, and lifting requirements.
Also consider whether the equipment can be transported into the facility and installed without major structural changes.
Energy costs can significantly affect the total cost of operating industrial equipment.
Review motor efficiency, fuel consumption, compressed air requirements, standby power use, and expected operating hours.
A machine with a lower purchase price may become more expensive over time if it consumes significantly more energy.
Equipment maintenance is essential for reliable plant operations.
Before purchasing, find out:
How often servicing is required
Which components need regular replacement
Whether spare parts are readily available
How easy the machine is to inspect and repair
Whether qualified technicians are available
Consider the manufacturer's service support and warranty coverage as well.
Industrial equipment must be suitable for its working environment and operated according to manufacturer instructions and applicable safety requirements.
Check machine guards, emergency stops, electrical protection, pressure ratings, operator training requirements, and access for safe maintenance.
For applicable workplaces in the United States, OSHA provides guidance on machine guarding and hazardous energy control, including lockout/tagout procedures.
The purchase price is only one part of the investment.
A more complete cost assessment should include:
Initial purchase price
Transportation and installation
Energy and fuel consumption
Routine maintenance
Spare parts and repairs
Operator training
Downtime and lost production
Expected service life
Comparing total ownership costs helps businesses make more informed equipment decisions.
Both new and used equipment can be suitable investments. The right option depends on the facility's requirements, available budget, production schedule, and expected equipment life.
New machinery may be a better choice when a facility requires specific configurations, current technology, manufacturer support, or a dependable warranty.
It may also be appropriate when equipment is essential to a critical production process and the cost of unexpected downtime is high.
Used industrial equipment may help businesses manage capital expenses while meeting their production requirements.
However, inspect the machine carefully before purchasing. Review its service records, operating hours, component condition, repair history, and availability of replacement parts.
For specialized equipment, consider an independent technical inspection before completing the transaction.
Regular maintenance helps equipment operate safely and efficiently. It also gives maintenance teams an opportunity to identify wear, leaks, unusual noise, vibration, and other warning signs.
A practical maintenance program should include the following activities.
Use the manufacturer's service manual to establish inspection intervals, lubrication requirements, component replacement schedules, and operating limits.
Check for visible damage, leaks, loose connections, unusual vibration, overheating, and abnormal operating sounds.
Document inspection findings so maintenance teams can identify recurring problems.
Track relevant operating data such as temperature, pressure, vibration, energy consumption, and production output.
Changes in these readings may indicate developing equipment problems.
Identify components that could cause extended downtime if they fail. Maintain suitable inventory based on equipment criticality, supplier lead times, and replacement costs.
Employees should understand correct operating procedures, equipment limitations, warning indicators, and reporting requirements.
Maintenance work must follow appropriate energy isolation and safety procedures.
Important safety reminder: Before servicing machinery, workers must follow the applicable hazardous-energy control procedures. OSHA's lockout/tagout guidance explains how equipment is isolated and rendered inoperative to help prevent unexpected startup or the release of stored energy.
Before purchasing industrial machinery, use this checklist to review the most important requirements.
Confirm the equipment's intended application.
Determine the required operating capacity.
Review the manufacturer's technical specifications.
Check installation and space requirements.
Evaluate energy and operating costs.
Confirm spare parts and service availability.
Review safety features and applicable compliance requirements.
Compare warranty terms and supplier support.
Inspect used equipment and verify its service history.
Calculate the expected total cost of ownership.
A structured evaluation helps reduce purchasing risks and ensures that the equipment fits the facility's actual operating needs.
Choosing industrial plant equipment requires evaluating production capacity, operating conditions, energy efficiency, safety requirements, and maintenance needs. Compare manufacturer specifications and total ownership costs to ensure each machine meets your facility's requirements. For used equipment, review service records, inspect critical components, and verify parts availability before purchasing. A well-informed selection can help improve operational reliability, reduce downtime, and support long-term productivity.
Examples include pumps, compressors, conveyors, boilers, generators, cooling systems, processing machinery, storage tanks, cranes, forklifts, and water treatment systems.
Industrial machinery often refers to machines that perform specific production or processing tasks. Plant equipment can be a broader term that also includes supporting systems such as pumps, compressors, power distribution, cooling, and material handling equipment. The terminology may vary between industries.
Manufacturing, mining, food processing, chemical production, oil and gas, power generation, water treatment, construction materials, and pharmaceutical industries all use industrial equipment.
Identify your production requirements, compare technical specifications, assess installation needs, evaluate energy consumption, review maintenance support, and calculate total ownership costs.
Used equipment can be a cost-effective option when its condition, service history, specifications, and parts availability meet your requirements. A thorough inspection is important before purchase.
Maintenance frequency depends on the equipment type, operating conditions, manufacturer recommendations, and usage. Follow the service manual and establish an inspection schedule based on equipment criticality and operating history.
Costs depend on equipment type, capacity, specifications, brand, condition, installation requirements, energy consumption, maintenance, and spare parts availability.
Choosing the right industrial plant equipment is an investment in your facility's productivity, efficiency, and long-term performance. The right machinery can help reduce downtime, streamline operations, improve workplace safety, and control operating costs.
Before making a purchase, compare equipment specifications, inspect its condition, review maintenance requirements, and consider the total cost of ownership. Whether you need new machinery or reliable used equipment, make sure it matches your production demands and future operational goals.
Ready to find the right equipment for your operation? Explore the industrial machinery available at Boom & Bucket, compare your options, and take the next step toward a more productive facility.
Explore available equipment at Boom & Bucket and find machinery that fits your job requirements and budget.
