9 Min read
September 18, 2025
If you're looking for a reliable and powerful skid steer loader, the New Holland LS180 is a great choice. Known for its robust performance, versatility, and advanced technology, the LS180 is an excellent option for various industries, including agriculture, construction, and landscaping. In this guide, we'll cover everything you need to know about the New Holland LS180, including its specs, engine, lift capacity, and where to find one for sale.
The New Holland LS180 is a skid steer loader used for construction, landscaping, farming, loading, grading, and material-handling tasks.
Browse all equipment
Published LS180.B specifications list a rated operating capacity of approximately 2,200 pounds. Capacity may vary by model and configuration.
The LS180.B has an approximate operating weight of 7,095 pounds before adding attachments or optional equipment.
Compatible options may include buckets, forks, augers, grapples, trenchers, breakers, brush cutters, sweepers, and snow equipment.
A properly maintained LS180 can be reliable, but condition, service history, hydraulic performance, and previous use should be carefully inspected.
The New Holland LS180 remains useful for construction, landscaping, farming, and property maintenance. Its productivity depends on machine condition, operator skill, attachment selection, and regular maintenance. A well-maintained LS180 can handle grading, loading, pallet work, debris cleanup, and material movement efficiently. Buyers should focus on hydraulic response, engine performance, control smoothness, lift-arm wear, and service history rather than relying on hours alone.
The New Holland LS180 is packed with features designed to make your work faster and more efficient. Built for power, stability, and ease of operation, this skid steer loader is ready to tackle tough jobs. Here are some of the standout features that make the LS180 a leading choice in its class:
Comfortable Operator Environment: The LS180 offers a spacious, ergonomic cabin that enhances operator comfort during long hours of use. The adjustable seating, intuitive controls, and excellent visibility help reduce operator fatigue.
Hydraulic System: The LS180 features a powerful hydraulic system that allows you to easily lift, push, and maneuver heavy loads.
Maneuverability: Its compact size and excellent maneuverability make it ideal for working in tight spaces without sacrificing performance.
At the heart of the New Holland LS180 is its powerful engine. Equipped with a New Holland LS180 engine that is built for optimal performance, this machine delivers impressive horsepower and fuel efficiency.
Engine Specs: The LS180 is powered by a reliable turbocharged engine that offers around 59 horsepower, ensuring you can tackle even the most demanding tasks with ease.
Fuel Efficiency: Thanks to its advanced engine technology, the LS180 is known for fuel efficiency, helping you save on operating costs while minimizing your environmental impact.
Durability: The engine is designed for long-lasting performance, reducing the frequency of repairs and maintenance.
The New Holland LS180 engine is built to handle a variety of tasks, from lifting and digging to pushing and transporting materials. Its durability and reliability make it a top choice for those in industries requiring heavy-duty equipment.
One of the key considerations when choosing a skid steer loader is its lift capacity. The New Holland LS180 lift capacity is designed to support demanding tasks such as lifting heavy loads and handling large attachments.
Rated Operating Capacity: The LS180 has a rated operating capacity of 1,800 pounds (816 kg), which is perfect for handling various types of materials, including dirt, gravel, and construction debris.
Tipping Load: With a tipping load of around 3,600 pounds (1,633 kg), the LS180 is capable of lifting and tipping large loads, making it highly efficient for construction and other heavy-duty work.
Hydraulic System: The high-performance hydraulic system enhances the lift capacity, allowing the LS180 to perform reliably under load without compromising stability.
Whether you're lifting dirt, rocks, or other materials, the New Holland LS180 provides the strength and stability you need to get the job done efficiently.
For a clearer picture of what the New Holland LS180 has to offer, here’s a breakdown of the key New Holland LS180 specs:
Engine Power: 59 hp (44 kW)
Operating Weight: 5,000 pounds (2,268 kg)
Lift Capacity: 1,800 pounds (816 kg)
Tipping Load: 3,600 pounds (1,633 kg)
Bucket Capacity: 0.55 cubic yards (0.42 m³)
Hydraulic Flow: 20.6 gpm (78 l/min)
Dimensions: 69 inches (1,752 mm) wide, 81 inches (2,057 mm) height
Travel Speed: 6.9 mph (11.1 km/h)
These specifications highlight the New Holland LS180 as a powerful and capable skid steer loader, well-suited for a wide range of tasks, from excavation and material handling to lifting and grading.
There are many reasons why the New Holland LS180 is a popular choice among operators. Here are some of the top advantages:
Durability: Built with high-quality materials, the LS180 can handle tough work environments, making it a great long-term investment.
Fuel Efficiency: Thanks to its efficient engine, you can complete more work while using less fuel, saving money over time.
Versatility: The LS180 can be equipped with various attachments, including buckets, forks, and augers, making it a versatile tool for different applications.
Ease of Maintenance: The LS180 is designed for easy servicing, reducing downtime and keeping maintenance costs low.
If you're in the market for a New Holland LS180 for sale, you're in luck. This popular skid steer loader is available through various channels:
Authorized Dealers: The best way to buy a new LS180 is through an authorized New Holland dealership. These dealers often offer financing options, warranties, and maintenance services.
Online Marketplaces: Websites like eBay, TractorHouse, and MachineryTrader are great places to find new and used New Holland LS180 models for sale.
Used Equipment: If you're looking for a more affordable option, used New Holland LS180 loaders can be found at auctions or through dealers specializing in pre-owned equipment. Be sure to inspect the machine thoroughly and check its maintenance history before purchasing.
Boom and Bucket: Boom and Bucket is a fantastic online marketplace for buying and selling used construction equipment. They offer a wide selection of pre-owned skid steers, including the New Holland LS180. With a focus on quality and transparency, Boom and Bucket allows you to browse equipment listings, view detailed specifications, and even request financing options.
Before buying a used LS180, verify:
Model and serial number
Engine hours and service records
Cold-start performance
Hydraulic leaks or slow movement
Lift-arm pins and bushings
Drive response and braking
Tire condition
Safety interlocks
Attachment plate condition
Signs of welding or structural repairs
Always test the machine under load and at operating temperature. A professional inspection is recommended for remote or high-value purchases.
The New Holland LS180 is versatile and capable of handling various tasks. Here are some common uses for this powerful skid steer loader:
Construction: The LS180 is ideal for moving materials, grading, and clearing debris on construction sites.
Agriculture: Farmers use the LS180 for tasks such as hauling feed, loading bales, and clearing fields.
Landscaping: With its excellent maneuverability and lift capacity, the LS180 is perfect for landscaping projects, including moving soil, rocks, and mulch.
Snow Removal: In winter, the LS180 can be fitted with snow plows and other attachments to help clear driveways and parking lots.
Its impressive specs and capabilities make the New Holland LS180 suitable for a wide range of industries and tasks.
The New Holland LS180 is suitable for:
Loading soil, gravel, mulch, and debris
Rough grading and site preparation
Pallet and material handling
Farm and livestock work
Landscaping and property maintenance
Snow removal
Trenching and drilling with compatible attachments
Its compact size makes it useful on residential sites, farms, yards, and confined construction areas.
Monitoring these metrics helps owners identify rising costs, declining performance, and maintenance needs early.
Common LS180 attachments include:
General-purpose buckets
Grapple buckets
Pallet forks
Trenchers
Hydraulic breakers
Brush cutters
Snow blades
Sweepers
Bale spears
Before purchasing an attachment, confirm coupler fit, hydraulic flow, pressure requirements, attachment weight, hose connections, and electrical controls. Physical fit alone does not guarantee proper operation
Check hydraulic fluid level, filter condition, leaks, damaged hoses, cylinder drift, and attachment flow requirements.
Inspect the battery, cables, starter, fuel filters, air intake, and fuel system for air leaks.
Clean the radiator and oil cooler, check coolant level, inspect belts, and verify fan operation.
Check tire pressure, control linkage, brakes, drive chains, pumps, and drive motors.
Inspect fuses, relays, grounds, wiring, seat switches, and restraint-bar sensors. Never bypass safety systems.
To improve LS180 reliability:
Check engine oil, coolant, and hydraulic fluid daily.
Inspect hoses, cylinders, and fittings for leaks.
Clean the radiator and cooling package.
Grease lift-arm and attachment pivot points.
Maintain correct tire pressure.
Replace filters and fluids on schedule.
Test alarms, seat belts, and safety interlocks.
Repair overheating or hydraulic noise promptly.
Use the correct operator's manual for the machine's exact model and serial number.
No. Specifications and components may differ, so always confirm the exact model and serial number.
Published LS180.B data lists approximately 2,200 pounds.
Yes, when the attachment matches the machine's hydraulic flow, pressure, coupler, weight, and control requirements.
Yes. It can handle soil, mulch, stone, grading, cleanup, drilling, and material movement.
Yes. It can move feed, manure, pallets, bales, and other agricultural materials with suitable attachments.
Common age-related concerns include hydraulic leaks, overheating, hard starting, drive issues, worn pins, and electrical faults.
Follow the operator's manual and shorten service intervals when working in dusty, muddy, hot, or attachment-heavy conditions.
Check the serial number, cold start, hydraulics, drive system, lift arms, safety systems, tires, and maintenance records.
Only when the trailer, axles, hitch, tires, and tow vehicle are rated for the machine, attachment, fuel, and securement equipment.
The New Holland LS180 is a top-performing skid steer loader with powerful features, including a reliable engine, impressive lift capacity, and versatile specifications. Whether you're in construction, agriculture, or landscaping, the LS180 offers the performance and durability you need to get the job done. If you're looking to purchase a New Holland LS180 for sale, check out authorized dealers, online listings, or used equipment options. With its solid design and exceptional performance, the New Holland LS180 is sure to be a valuable addition to your fleet.
