4 Min read
November 4, 2025
Water pooling in your yard or around your foundation can lead to costly damage, including erosion, mold, and structural issues. One of the most effective solutions is French drain construction, a proven drainage method used in residential, commercial, and construction projects.
This complete guide covers everything you need to know, including:
What a French drain is
When you should install one
Step-by-step French drain installation
Cost breakdown (DIY vs professional)
Best materials and equipment
Common mistakes to avoid
Whether you're a contractor, homeowner, or equipment operator, this guide will help you build a long-lasting and efficient drainage system.
Browse all Trenchers
A French drain is a trench filled with gravel and a perforated pipe that redirects water away from structures, foundations, or low-lying areas. It works by collecting excess groundwater and channeling it safely to a drainage outlet.
French drains are commonly used for:
Yard drainage
Construction site drainage
You should consider French drain installation if you notice:
Standing water in your yard after rain
Water pooling near your foundation
Basement leaks or dampness
Soil erosion around structures
Poor drainage in landscaping
Installing a French drain early can prevent expensive repairs and long-term damage.
Different projects require different types of drainage systems.
Installed around the outside of a building to prevent water from reaching the foundation.
Installed inside basements to collect water and redirect it to a sump pump.
A shallow trench that intercepts water flowing downhill before it reaches a problem area.
Designed to collect surface water, often used in driveways or patios.
Identify where water collects and where it should be redirected.
Ensure a minimum slope of 1% (1 inch per 10 feet) for proper drainage.
Typical trench dimensions:
Depth: 6-24 inches
Width: 6-12 inches
For larger projects, contractors use:
trenchers
skid steers
Using the right equipment improves efficiency and accuracy.
Line the trench with filter fabric to prevent soil from clogging the system.
Add 2–3 inches of gravel to support the pipe and improve water flow.
Place the pipe with holes facing downward to allow water to enter from below.
Fill the trench with gravel to promote drainage.
Wrap the fabric over the gravel and cover with soil or decorative stone.
The cost varies depending on size, materials, and labor.
trench length and depth
soil conditions
materials used
equipment required
labor costs
Using the right materials is critical for performance.
PVC or corrugated pipe
Allows water to flow into the system
Clean, washed gravel (¾ inch recommended)
Prevents clogging and improves flow
Filters out soil
Extends system lifespan
Browse all Mini Excavators
French drain construction often involves heavy equipment, including:
trenchers for narrow trenches
mini excavators for deeper digging
skid steers for material handling
dump trucks for hauling gravel
This aligns with real-world construction workflows and improves jobsite efficiency.
Avoid these costly mistakes:
Water won’t flow without proper grading.
Leads to clogged pipes and system failure.
Fine gravel can block drainage.
Water must exit safely away from structures.
Protects foundations and basements from flooding.
Eliminates standing water.
Maintains landscape stability.
Can last 20–30 years with proper installation.
Best for small projects.
Pros:
lower cost
flexible timeline
Cons:
labor-intensive
risk of errors
Best for large or complex drainage issues.
Pros:
expert installation
long-term reliability
Cons:
higher upfront cost
In some cases, additional solutions may be needed:
sump pump systems
grading improvements
stormwater drainage systems
Typically $10–$75 per linear foot depending on DIY vs professional installation.
Usually 6–24 inches, depending on drainage needs.
A properly installed system lasts 20–30 years.
Yes, but proper slope, materials, and installation are critical.
Clean, washed gravel around ¾ inch size is ideal.
French drain construction is one of the most effective and affordable solutions for managing water drainage issues. Whether you're protecting your foundation or improving yard drainage, a properly installed French drain can prevent long-term damage and save money.
With the right materials, equipment, and installation process, you can build a drainage system that lasts for decades.
Planning a drainage or excavation project?
Explore Boom & Bucket’s marketplace to find trenchers, excavators, and construction equipment to get the job done efficiently.
