12 Min read
July 1, 2026
Choosing the right heavy equipment tire size is essential for maximizing traction, stability, load capacity, fuel efficiency, and overall machine performance. Whether you operate a wheel loader, skid steer, telehandler, or other heavy equipment, the correct tires can reduce wear, lower operating costs, and improve jobsite productivity. In this guide, you'll learn how to read tire sizes, compare radial and bias tires, understand key tire specifications, and choose the best fit for your equipment and working conditions.
The correct tire size depends on your machine model, axle configuration, load requirements, and manufacturer specifications. Always use approved tire sizes to maintain lifting capacity, stability, steering performance, and drivetrain reliability.
Browse all Articulated trucks
Heavy equipment tire sizes indicate the tire's width, construction type, and rim diameter. For example, 23.5R25 represents a tire that is 23.5 inches wide, uses radial construction, and fits a 25-inch wheel.
Radial tires provide better fuel efficiency, ride comfort, and tread life, making them ideal for most construction and hauling applications. Bias tires offer greater sidewall strength and puncture resistance, making them better suited for demolition, forestry, and quarry operations.
Replace heavy equipment tires when they exhibit excessive tread wear, deep sidewall cracks, exposed steel belts, repeated air leaks, or structural damage. Routine inspections help identify problems before they lead to unexpected downtime.
Yes. Proper tire inflation reduces rolling resistance, improves traction, extends
tire life, and lowers fuel consumption. Underinflated tires can significantly increase operating costs while accelerating tread wear.
Selecting the right heavy equipment tire involves more than matching the size on the sidewall. Experienced contractors and fleet managers also consider machine specifications, load requirements, terrain, and daily operating conditions to maximize performance and safety.
Choosing the correct tire size and type helps improve traction, reduce operating costs, extend tire life, and keep equipment working efficiently across a wide range of construction and earthmoving applications.
Heavy equipment is engineered around specific tire dimensions. Tire size influences nearly every aspect of machine performance, including:
Machine stability
Load-carrying capacity
Ground pressure
Traction on different surfaces
Fuel efficiency
Ride quality
Steering response
Tire lifespan
Overall operating costs
Even a slight change in tire diameter or width can alter a machine's center of gravity, hydraulic performance, and manufacturer-rated lifting capacity. Using tires that meet the equipment manufacturer's specifications helps maintain safe operation and protects expensive drivetrain and axle components.
Unlike passenger vehicle tires, heavy equipment tires use specialized sizing systems designed for demanding construction, mining, agriculture, and industrial applications.
You'll commonly encounter tire markings such as:
17.5R25
23.5R25
20.5-25
12-16.5
14.00R24
405/70R20
Although these numbers may appear confusing, each part provides important information about the tire's dimensions and construction.
For example:
23.5R25
23.5 = Tire width in inches
R = Radial construction
25 = Rim diameter in inches
A tire labeled 20.5-25 follows a similar format, except the dash indicates bias-ply construction instead of radial construction.
Understanding these numbers makes it easier to select replacement tires that maintain proper machine performance and manufacturer specifications.
Knowing how to interpret tire markings is one of the most valuable skills when replacing heavy equipment tires.
Consider this example:
Tire Size: 17.5R25
Some tires also include additional information such as:
Load Index
Speed Rating
Ply Rating
Tire Compound
Tread Pattern
Service Type (L, E, G, C classifications)
These specifications help determine whether a tire is appropriate for loaders, graders, scrapers, haul trucks, or other heavy equipment applications.
One of the first decisions buyers face is choosing between radial and bias-ply tires. Both have advantages depending on the application.
Radial tires feature steel belts running perpendicular to the tread, allowing greater sidewall flexibility while maintaining a stable footprint.
Benefits include:
Better traction
Lower rolling resistance
Reduced fuel consumption
Longer tread life
Improved operator comfort
Better high-speed performance
These tires are commonly used on wheel loaders, articulated dump trucks, and haul trucks operating on improved surfaces.
Bias tires use multiple overlapping layers of reinforcing cords that create a stronger, more rigid sidewall.
Advantages include:
Greater resistance to cuts and punctures
Stronger sidewall protection
Lower purchase cost
Better performance in rocky environments
Bias tires remain popular in demolition, forestry, mining, and other demanding applications where sidewall damage is common.
Although manufacturers offer multiple tire options, certain sizes are commonly found across the industry.
Always verify tire recommendations in the manufacturer's operator's manual before replacing tires, as approved sizes vary by model and configuration.
Wheel loaders depend on properly sized tires to maintain lifting stability, traction, and breakout force. Larger tires increase flotation on loose surfaces while supporting heavier bucket loads.
Typical sizes include:
17.5R25
20.5R25
23.5R25
26.5R25
Operators working in quarries or aggregate yards often choose specialized rock tread patterns for improved durability and traction.
Skid steer tires are designed to withstand constant turning, abrasion, and high side loads.
Popular sizes include:
10-16.5
12-16.5
14-17.5
Contractors working on soft ground may choose wider flotation tires to reduce rutting and improve traction.
Backhoes typically use different tire sizes for the front and rear axles because of their unique weight distribution.
Common combinations include:
Front: 12.5/80-18
Rear: 19.5L-24
Maintaining the correct tire combination helps preserve stability during excavation and loader operations.
Telehandlers often operate on rough construction sites while lifting heavy materials to elevated work areas.
Common tire sizes include:
13.00-24
14.00-24
405/70R20
Choosing the correct tire ensures stable lifting performance while minimizing ground disturbance.
Selecting the correct tire size involves more than matching the numbers printed on the sidewall. Consider the following factors before purchasing replacement tires:
Always begin with the tire sizes approved by the equipment manufacturer. Using unapproved sizes may affect load capacity, braking performance, and drivetrain reliability.
Different surfaces require different tire characteristics:
Mud and clay benefit from aggressive tread patterns.
Rocky terrain demands reinforced sidewalls.
Asphalt favors smoother tread designs with lower rolling resistance.
Sand requires wider flotation tires to reduce sinking.
Machines that frequently carry heavy loads should use tires with appropriate load ratings and ply ratings to maintain safety and durability.
High-hour machines often benefit from premium radial tires that provide longer tread life and improved fuel efficiency over time.
Maintaining proper tire pressure is one of the easiest ways to improve performance and extend tire life.
Incorrect inflation affects:
Fuel efficiency
Tread wear
Traction
Ride quality
Load capacity
Operator comfort
Running tires below the recommended pressure can result in:
Excessive sidewall flex
Heat buildup
Rapid shoulder wear
Higher fuel consumption
Reduced stability
Premature tire failure
Too much pressure creates different problems:
Center tread wear
Reduced traction
Rougher ride
Increased impact damage
Smaller contact patch
Daily pressure checks are especially important when operating in environments with significant temperature fluctuations.
One often-overlooked factor when selecting heavy equipment tires is ground pressure.
Ground pressure measures how much machine weight is applied to the surface beneath the tire.
Advantages include:
Lower ground pressure
Better flotation
Reduced soil compaction
Improved traction on sand and mud
Greater stability
Ideal for:
Agriculture
Soft soil
Landscaping
Wet construction sites
Advantages include:
Easier steering
Better performance on hard surfaces
Reduced initial cost
Ideal for:
Asphalt
Concrete
Warehouses
Urban construction
Browse all Bulldozers
9815 hours
$95,000 USD
3940 hours
$102,059 USD
7284 hours
$264,375 USD
10294 hours
$70,000 USD
326 hours
$48,000 USD
10343 hours
$30,000 USD
45062 hours
$200,000 USD
19565 hours
$200,000 USD
13004 hours
$105,000 USD
3938 hours
$150,000 USD
1464 hours
$91,259 USD
496 hours
$127,500 USD
Matching tire width to site conditions improves efficiency while minimizing surface damage.
Every jobsite presents unique challenges. Choosing the correct tire for the terrain improves productivity while reducing unnecessary wear.
Understanding terrain conditions before purchasing tires can significantly reduce replacement costs over the equipment's lifespan.
Heavy equipment tires are available in several tread designs optimized for different applications.
Designed for:
Mining
Quarry operations
Demolition
Benefits:
Thick tread depth
Excellent cut resistance
Maximum durability
Ideal for:
Construction
Earthmoving
Material handling
Benefits:
Good balance of traction and wear
Versatile performance
Commonly used for:
Asphalt work
Road construction
Industrial yards
Benefits:
Longer tread life
Better fuel economy
Reduced vibration
Choosing the proper tread pattern often has a greater impact on productivity than simply increasing tire size.
Different work environments require different tire technologies.
Solid tires eliminate punctures but generally provide a harsher ride and reduced traction compared to pneumatic tires.
Inspecting tread wear helps identify mechanical problems before they become expensive repairs.
Usually caused by:
Overinflation
Typically indicates:
Underinflation
May suggest:
Wheel alignment issues
Suspension wear
Improper axle geometry
Often caused by:
Worn suspension components
Improper balancing
Loose wheel bearings
Regular inspections improve equipment reliability while extending tire service life.
Follow these recommendations to maximize tire performance:
Check pressure before daily operation.
Measure pressure when tires are cold.
Use calibrated pressure gauges.
Adjust for seasonal temperature changes.
Replace damaged valve stems immediately.
Monitor tires after heavy impacts.
Consistent tire pressure management reduces downtime and improves fuel efficiency.
Heavy equipment tires should be replaced when they no longer provide safe or efficient performance.
Signs include:
Excessive tread wear
Deep sidewall cracks
Repeated air leaks
Exposed steel belts
Severe chunking
Bulges
Irregular wear
Frequent punctures
Replacing worn tires before failure improves safety while reducing unexpected downtime.
Many buyers focus only on tire diameter while overlooking other important factors.
Avoid these common mistakes:
Choosing the cheapest tire instead of the best value.
Ignoring manufacturer-approved tire sizes.
Mixing radial and bias tires on the same axle.
Selecting incorrect load ratings.
Overlooking jobsite conditions.
Running improper tire pressure.
Ignoring tread pattern differences.
Forgetting future workload requirements.
Proper tire selection reduces maintenance costs and improves machine performance over the long term.
Whether you're purchasing new tires, inspecting used equipment, or performing routine maintenance, a thorough tire inspection helps prevent costly downtime and unexpected failures. Use this checklist before putting any machine into service.
Inspect the tread for:
Uneven wear patterns
Excessive tread loss
Chunking or tearing
Embedded rocks or debris
Missing tread blocks
Uneven tread wear often signals incorrect inflation, alignment issues, or suspension problems that should be addressed before replacing the tire.
Examine the sidewalls for:
Cuts or punctures
Bulges
Deep cracks
Exposed cords
Impact damage
Sidewall damage cannot usually be repaired safely and often requires immediate replacement.
Verify that all tires match the manufacturer's recommended inflation pressure. Consistent pressure improves traction, extends tread life, and reduces fuel consumption.
Inspect wheels for:
Bent rims
Cracks
Loose wheel hardware
Rust or corrosion
Air leaks around the bead
Damaged rims can cause slow leaks and reduce tire performance.
Ensure valve stems are:
Secure
Free of cracks
Protected by valve caps
Not leaking
Replacing inexpensive valve stems during tire service can prevent future air loss.
When inspecting used heavy equipment, tire condition often reveals how well the machine has been maintained. Because heavy equipment tires represent a significant ownership cost, carefully evaluating them before purchase can help you avoid unexpected expenses.
Look for:
Matching tire brands and sizes
Even tread wear across all tires
No major sidewall repairs
Proper inflation
Minimal weather cracking
No exposed steel belts
Appropriate tread pattern for the intended application
Maintenance records, if available
If the tires require immediate replacement, factor those costs into the purchase price before making an offer.
Many medium-size wheel loaders use 20.5R25 or 23.5R25 tires, although the correct size depends on the manufacturer and model.
Only if the equipment manufacturer approves the change. Installing oversized tires can alter machine stability, steering geometry, lifting capacity, and drivetrain performance.
Radial tires typically cost more because they provide longer tread life, improved fuel efficiency, better ride quality, and greater operating performance over time.
Heavy-duty rock tread (L5) radial or bias tires with reinforced sidewalls are commonly recommended for mining, quarry, and demolition applications.
Service life depends on tire quality, operating conditions, maintenance practices, inflation pressure, and workload. Properly maintained premium tires often deliver thousands of operating hours.
Inspect tire pressure daily before operating heavy equipment, especially on machines working long shifts or carrying heavy loads.
Common causes include:
Incorrect inflation
Poor wheel alignment
Suspension wear
Overloading
Improper tire rotation
Aggressive operating conditions
Solid tires eliminate flats and punctures but provide a firmer ride. Pneumatic tires offer better traction, comfort, and shock absorption for most construction applications.
Yes. Properly sized tires reduce rolling resistance, improve traction, and help optimize fuel consumption. Incorrect tire sizing can increase engine load and operating costs.
Replace the tire if it has major sidewall damage, exposed cords, severe tread separation, or structural defects. Minor tread punctures may be repairable if approved by the tire manufacturer.
Selecting the right tires is only one part of purchasing reliable heavy equipment. The condition of the machine, maintenance history, and overall inspection quality are equally important.
At Boom & Bucket, buyers can shop a wide selection of professionally inspected used heavy equipment from trusted sellers across North America. Whether you're looking for wheel loaders, skid steers, telehandlers, articulated dump trucks, or other construction equipment, you'll find detailed listings designed to help you make informed purchasing decisions.
Boom & Bucket also provides:
Comprehensive equipment inspections
Transparent equipment listings
Educational buying resources for contractors and fleet managers
By combining the right equipment with the correct tire selection, you can maximize productivity, reduce maintenance costs, and improve long-term return on investment.
Selecting the right heavy equipment tire size is one of the most important decisions you can make for your fleet. Proper tire sizing improves machine stability, traction, fuel efficiency, load-carrying capability, and overall equipment performance while helping reduce maintenance costs and unexpected downtime.
When evaluating tires, look beyond the sidewall dimensions. Consider load ratings, ply ratings, tread patterns, jobsite conditions, inflation pressure, and future operating needs to ensure the tires match your application. Whether you're replacing worn tires, expanding your fleet, or purchasing used heavy equipment, choosing the right tire from the beginning helps protect your investment and keeps your projects running efficiently.
If you're searching for dependable used heavy equipment, Boom & Bucket makes it easy to compare professionally inspected machines, explore financing options, and find equipment ready for your next job. With the right machine and the right tires, you'll be well equipped to tackle demanding construction, mining, landscaping, and material handling projects with confidence.
Browse all Bucket trucks
194509 miles
$15,000 USD
118535 miles
$44,500 USD
196040 miles
$30,000 USD
100394 miles
$31,000 USD
224159 miles
$59,000 USD
132063 miles
$55,000 USD
63223 hours
$95,000 USD
65574 miles
$15,000 USD
184982 miles
$25,000 USD
226914 miles
$32,000 USD
273067 miles
$14,000 USD
10182 hours
$85,000 USD
More in Insight
