4 Min read
October 7, 2025
Building a new home or commercial structure is exciting - but skipping proper inspections can lead to costly mistakes. New construction inspections ensure every phase of your project meets safety standards, building codes, and quality expectations.
In this complete guide, you’ll learn:
What new construction inspections are
All inspection phases explained
A detailed inspection checklist
Costs and timelines
Expert tips to avoid failed inspections
Browse all Backhoes
New construction inspections are professional evaluations conducted at different stages of a building project to ensure everything is built safely and according to code.
These inspections help:
Catch issues early before they become expensive
Ensure compliance with local building regulations
Protect your investment and long-term property value
Understanding each inspection stage helps you stay on track and avoid delays.
Before concrete is poured, inspectors check:
Soil condition and compaction
Footings and reinforcement
Mistakes here can compromise the entire structure.
Once the structure is up, inspectors review:
Wall framing and roof structure
Window and door placement
Structural integrity
This is one of the most critical phases.
Inspectors examine:
Electrical wiring
Plumbing systems
HVAC installations
Insulation
This is your last chance to fix hidden issues before walls are closed.
After construction is complete:
Fixtures and finishes are checked
Systems (electrical, plumbing, HVAC) are tested
Safety compliance is verified
Conducted before your builder warranty expires:
Identifies defects that appeared after occupancy
Ensures builder fixes remaining issues
Here’s a simplified but powerful checklist to follow:
Foundation cracks
Proper framing alignment
Roof stability
Correct wiring installation
Functioning outlets and switches
Panel safety compliance
Leak-free pipes
Proper drainage
Water pressure consistency
Proper ventilation
System efficiency
Thermostat functionality
Doors and windows sealing
Flooring and wall finishes
Exterior grading and drainage
Inspection costs vary depending on location and property size.
Browse all Backhoes
Single inspection: $300 - $600
Full inspection package: $1,000 - $3,000+
Property size
Number of inspection phases
Inspector experience
Location
Investing in inspections can save thousands in future repairs.
Individual inspection: 1 to 3 hours
Full project (multiple phases): Spread across the construction timeline
Delays can occur if:
Issues are found
Re-inspections are required
Even new builds can have problems. Common ones include:
Improper wiring
Plumbing leaks
Poor insulation
Structural misalignment
Code violations
Catching these early prevents costly rework later.
Failing an inspection isn’t the end - it’s a safeguard.
Here’s what happens:
Inspector provides a report of issues
Builder fixes the problems
A re-inspection is scheduled
You cannot proceed to the next phase until you pass.
Want a smooth inspection process? Follow these tips:
Don’t rely solely on builder inspections - get a third-party expert.
You’ll learn about your property and spot issues firsthand.
Keep records of reports, fixes, and approvals.
Avoid delays by planning inspections ahead of time.
Skipping inspections might save money upfront - but it can cost far more later.
Ensures safety and compliance
Prevents expensive repairs
Improves build quality
Protects long-term investment
Typically: foundation, framing, pre-drywall, and final inspections. Some areas also require additional code-specific checks.
Usually the homeowner, but sometimes builders include inspections in the contract.
Yes. Even new homes can fail due to code violations or poor workmanship.
Absolutely. It’s the best time to catch hidden issues before walls are sealed.
Yes, most local governments require inspections at key construction stages.
New construction inspections are a critical step in ensuring your project is safe, compliant, and built to last. From foundation to final walkthrough, each phase plays a key role in protecting your investment.
If you’re planning a build, don’t skip inspections - they’re one of the smartest decisions you can make.
