September 14, 2026
Pipeline construction requires specialized machinery for clearing rights-of-way, excavating trenches, handling pipe, welding, lowering pipe, backfilling, and restoring the worksite. The right pipeline equipment depends on the project's size, terrain, soil conditions, pipe dimensions, lifting requirements, and budget.
Whether you're planning a pipeline project or looking for used pipeline equipment, understanding the main machine types and specifications can help you build a more productive and cost-effective equipment fleet.
Pipeline equipment includes the heavy machinery and specialized tools used to construct, install, maintain, and restore pipeline systems. Common equipment includes excavators, sidebooms, trenchers, bulldozers, loaders, cranes, pipe-handling equipment, compactors, and specialized attachments.
Browse all Excavators
Pipeline construction typically moves through several coordinated stages, including clearing, pipe stringing, trenching, welding, coating, lowering, backfilling, and restoration.
Different machines perform different jobs throughout the pipeline construction process.
Excavators are commonly used for trenching, excavation, material handling, and backfilling. Machine size and configuration should match trench depth, soil conditions, access, and lifting requirements.
Sidebooms, also called pipelayers in many pipeline applications, are designed to lift, support, align, and lower pipe. Multiple sidebooms may work together when lowering a welded pipe string into a trench.
Bulldozers are commonly used for right-of-way clearing, grading, access-road construction, backfilling, and site restoration.
Trenchers can excavate continuous trenches efficiently where soil and project conditions are suitable. Wheel trenchers and backhoes are among the equipment used for pipeline trenching.
Wheel loaders move soil, aggregate, pipe-related materials, and other construction supplies around staging areas and job sites.
Cranes can be used for lifting and positioning heavy pipe, equipment, and construction materials when the application and lift plan require them.
Compactors help achieve the required soil density during backfilling and site restoration.
Depending on the project, contractors may also use pipe bending machines, welding equipment, coating equipment, vacuum excavation systems, rock excavation equipment, compressors, and specialized attachments.
Pipeline construction operates as a coordinated sequence rather than a series of isolated machine tasks. Equipment selection should therefore consider how each machine fits into the overall project workflow.
Choosing pipeline machinery starts with the project requirements.
Consider:
Pipeline size - Pipe diameter and weight affect lifting and handling requirements.
Trench requirements - Determine required digging depth, width, and reach.
Terrain - Hills, wetlands, rocky ground, and restricted access can change equipment requirements.
Soil conditions - Hard rock, clay, sand, and unstable ground may require different machines or attachments.
Project scale - Larger projects may require specialized equipment and coordinated equipment spreads.
Hydraulic requirements - Check flow and pressure requirements for attachments.
Transportation - Consider machine dimensions, weight, and mobilization requirements.
Utilization - Estimate how frequently each machine will operate.
Attachments - Choose equipment that supports the tools required for the project.
Budget - Consider both acquisition cost and long-term ownership costs.
The best pipeline equipment is not necessarily the largest machine. It is the machine that provides the required capacity and performance without creating unnecessary transportation, operating, or ownership costs.
Used pipeline equipment can help contractors expand their fleets while reducing upfront acquisition costs. However, the condition of the individual machine is more important than the brand name alone.
Before buying used pipeline equipment, evaluate:
Year and model
Operating hours
Maintenance history
Previous application
Engine condition
Hydraulic system
Undercarriage or tires
Frame and structural components
Boom and lifting components
Controls and electrical systems
Service records
Serial number or VIN
Inspection reports
Current market price
A higher-hour machine with documented maintenance and good component condition may provide better value than a lower-hour machine with an unknown history.
A thorough inspection can help identify potential repair costs before purchase.
Check for abnormal noise, smoke, leaks, fluid contamination, and signs of poor maintenance.
Inspect hoses, cylinders, pumps, valves, and connections for leaks, damage, or abnormal operation.
Look for excessive wear, damaged components, uneven wear, and signs of previous heavy use.
Inspect the frame, welds, boom, counterweights, lifting components, and other structural areas for cracks, bends, corrosion, or repairs.
Test operating controls, gauges, lights, alarms, and other electrical functions.
Confirm that included attachments are compatible, properly maintained, and suitable for the intended work.
Verify the serial number or VIN, ownership records, service history, inspection information, and available maintenance documentation.
When possible, have a qualified technician or equipment inspector evaluate the machine before purchase.
The purchase price is only one part of equipment ownership.
Consider:
Purchase price
Financing and interest
Transportation
Fuel
Preventive maintenance
Repairs
Tires or undercarriage
Insurance
Operator costs
Downtime
Depreciation
Expected resale value
Comparing total ownership costs can provide a better buying decision than choosing the machine with the lowest advertised price.
Pipeline equipment should be operated and maintained according to manufacturer requirements and applicable safety regulations.
Regular inspections should cover critical systems such as:
Brakes
Steering and controls
Hydraulic components
Tires or tracks
Lifting equipment
Structural components
Safety devices
Excavation work also requires careful planning. U.S. OSHA standards address hazards associated with trenching and excavation, while PHMSA provides pipeline-construction guidance covering activities such as trenching, pipe lowering, backfilling, and protection of pipe coatings.
For pipeline excavation near existing infrastructure, applicable damage-prevention requirements should also be followed.
Always follow the regulations applicable to the project location.
Several manufacturers produce equipment used in pipeline construction, but the best choice depends on the machine category and application.
Potential equipment brands include:
Komatsu
John Deere
Volvo Construction Equipment
CASE
Liebherr
Hitachi
Vermeer
Ditch Witch
For specialized pipeline equipment, compare manufacturer specifications, service support, parts availability, machine configuration, and application requirements rather than choosing solely by brand reputation.
For example, Caterpillar's pipeline equipment offerings include sidebooms, pipelayers, track-type tractors, excavators, and motor graders.
Ready to expand your fleet?
Compare used pipeline equipment by:
Make and model
Year
Operating hours
Condition
Location
Price
Before purchasing, compare the machine's specifications and inspection information with your project's actual requirements.
Common pipeline construction equipment includes excavators, sidebooms, pipelayers, bulldozers, trenchers, loaders, cranes, compactors, welding equipment, and specialized pipeline attachments.
Excavators, backhoes, and trenchers are commonly used for pipeline trenching. The appropriate machine depends on trench requirements, soil conditions, terrain, and project specifications.
Sidebooms, pipelayers, cranes, excavators, and other material-handling equipment can lift, position, align, and move pipe during construction.
A sideboom is specialized lifting equipment used to support, position, align, and lower pipe during pipeline construction. Multiple sidebooms may work together when lowering a welded pipe string into a trench.
Consider pipeline size, trench requirements, terrain, soil conditions, lifting capacity, hydraulic requirements, attachments, transportation needs, utilization, and total ownership costs.
Used pipeline equipment can offer lower acquisition costs, but buyers should evaluate operating hours, maintenance history, machine condition, specifications, inspection results, and expected repair costs.
Inspect the engine, hydraulics, undercarriage or tires, frame, lifting components, attachments, controls, electrical systems, documentation, and maintenance history.
Prices vary by equipment type, manufacturer, model, age, hours, specifications, condition, and market demand. Compare current listings and total ownership costs rather than purchase price alone.
Pipeline construction depends on equipment that can perform reliably across clearing, excavation, pipe handling, lowering, backfilling, and restoration.
Whether buying new or used pipeline equipment, focus on the requirements that directly affect your project: capacity, specifications, terrain, condition, utilization, maintenance, transportation, and total ownership cost.
For used equipment, inspect the individual machine carefully and compare its specifications, condition, hours, service history, and price with similar machines before purchasing.
