Trench Shoring: Types, Safety, Costs & Best Practices
9 Min read
David Baca
David Baca
September 21, 2026
Trench excavation is essential for utility installation, drainage, pipelines, and other construction projects, but unstable soil can create serious safety hazards. Trench shoring helps support excavation walls and protect workers while work is underway.
This guide explains trench shoring types, systems, safety requirements, costs, inspection practices, and best practices to help contractors understand their options and plan safer, more efficient excavation projects.
What Is Trench Shoring?
Trench shoring is a protective system used to support the sides of an excavation and help prevent cave-ins. Shoring can use timber, hydraulic, mechanical, or other engineered support systems. OSHA defines shoring as a structure designed to support excavation sides and prevent cave-ins.
Shoring is one type of protective system. Depending on site conditions, contractors may instead use or combine sloping, benching, or shielding systems. The appropriate method depends on factors such as soil conditions, excavation depth, nearby loads, groundwater, and surrounding structures.
Why Is Trench Shoring Important?
Trench walls can become unstable as soil conditions, water, weather, equipment loads, and nearby structures change. A properly designed and installed protective system reduces employees' exposure to cave-ins and other excavation hazards.
Under OSHA's construction excavation standard, employees generally must be protected from cave-ins by an adequate protective system unless an applicable exception applies, such as certain excavations less than 5 feet deep where a competent person finds no indication of a potential cave-in.
Shoring also helps contractors maintain a controlled excavation while allowing workers to install utilities, pipes, drainage systems, foundations, and other underground infrastructure.
Types of Trench Shoring Systems
Common trench shoring systems include:
Timber shoring: Uses timber uprights, wales, and cross braces to support trench walls.
Hydraulic shoring: Uses hydraulic cylinders with vertical or horizontal members to support excavation sides.
Mechanical shoring: Uses mechanically adjustable components to provide lateral support.
Aluminum hydraulic shoring: A lightweight, reusable system designed for specific trench applications.
Sheeting and shoring: Uses sheeting to retain soil together with structural support members.
Trench shields: Also called trench boxes, these protect workers by providing a zone of protection inside the excavation rather than directly supporting the trench walls.
The system must be appropriate for the excavation and installed according to applicable design requirements, manufacturer specifications, or approved tabulated data.
Trench Shoring vs. Trench Shielding
Trench shoring and trench shielding are related but serve different purposes.
Shoring supports the sides of an excavation to help prevent soil movement and cave-ins. Shielding uses a protective structure, commonly called a trench box, to protect workers within a designated area if a cave-in occurs.
A trench shield does not automatically make an excavation safe. OSHA requires shields to be installed and used so they are not subjected to loads beyond their design capacity and so workers are protected during installation, removal, movement, entry, and exit.
How to Choose the Right Trench Shoring System
Choosing a trench shoring system starts with the excavation rather than the equipment. Evaluate:
  1. Trench depth and width
  2. Soil classification and stability
  3. Groundwater and water accumulation
  4. Nearby buildings, roads, utilities, and foundations
  5. Surcharge loads from equipment, vehicles, and stored materials
  6. Required working space
  7. Installation and removal methods
  8. Expected duration of the excavation
  9. Access and egress requirements
  10. Applicable regulations and engineered design requirements
OSHA requires protective systems to have sufficient capacity for loads that are intended or could reasonably be expected to be applied to them.
Soil Classification and Trench Shoring
Soil conditions are a major factor when selecting excavation protection. OSHA's Subpart P classifies soil and rock based on site and environmental conditions, including their structure and composition.
The classification process is important when designing or selecting certain sloping, benching, timber shoring, and aluminum hydraulic shoring systems. Soil conditions can also change during excavation because of water, vibration, weather, or other site conditions.
A competent person should evaluate soil conditions and determine whether the selected protective system remains appropriate as work progresses.
Trench Shoring Safety Requirements
Safe trench shoring requires more than installing a support system. Key practices include:
  1. Inspect the excavation and protective system before work begins.
  2. Conduct required inspections during the shift and after rainstorms or other hazard-increasing events.
  3. Keep spoil, materials, and equipment at least 2 feet from the excavation edge unless adequate retaining measures are used.
  4. Provide safe access and egress for trenches 4 feet or deeper.
  5. Keep the required means of egress within 25 feet of lateral travel for workers.
  6. Protect workers from falling or rolling materials.
  7. Address hazardous atmospheres and water accumulation where applicable.
  8. Do not exceed the design capacity of shoring or shielding systems.
  9. Follow manufacturer instructions and approved design or tabulated data.
OSHA requires excavation inspections by a competent person before work starts and as needed throughout the shift, including after rainstorms or other events that could increase hazards.
What Is a Competent Person in Trenching?
A competent person is someone who can identify existing and predictable hazards and has the authority to take prompt corrective action.
For trenching work, the competent person plays an important role in evaluating soil conditions, determining the need for protective systems, inspecting excavations and shoring, identifying changing hazards, and removing workers from unsafe areas when necessary.
The competent person should also understand the applicable excavation requirements and the limitations of the protective system being used.
Trench Shoring Inspection Checklist
Before allowing workers to enter a protected trench, inspect:
  1. Shoring members for cracks, bending, deformation, or other damage
  2. Hydraulic components for leaks or loss of pressure
  3. Cross braces, uprights, and wales for proper installation
  4. Connections and locking mechanisms
  5. Trench shields for structural damage
  6. Evidence of soil movement, cracking, sloughing, or bulging
  7. Water accumulation or changing groundwater conditions
  8. Spoil piles and equipment near the trench edge
  9. Nearby structures, utilities, and surface loads
  10. Ladders, ramps, or other required means of egress
  11. Atmospheric conditions where hazardous atmospheres may exist
OSHA's excavation inspection guidance specifically calls for inspection of protective systems, surface conditions, spoil placement, access and egress, and other hazards before workers enter.
How Deep Can a Trench Be Without Shoring?
There is no single depth at which every trench automatically requires shoring. Under OSHA's federal construction standard, employees in excavations generally must be protected from cave-ins by an adequate protective system.
One exception applies to excavations less than 5 feet deep when examination of the ground by a competent person provides no indication of a potential cave-in. Stable rock is another specific exception.
For excavations 20 feet or less, OSHA provides options and design guidance for protective systems. Protective systems for excavations more than 20 feet deep must be designed by a registered professional engineer under the applicable requirements.
Local regulations may impose additional requirements, so contractors should verify the rules applicable to their project.
Trench Shoring Costs
Trench shoring costs vary significantly based on the system, trench dimensions, depth, soil conditions, project duration, equipment requirements, transportation, installation, and whether the system is purchased or rented.
Typical cost considerations include:
  1. Shoring or trench-box rental or purchase
  2. Delivery and transportation
  3. Installation and removal
  4. Engineering or design services
  5. Labor
  6. Pumps and water-control equipment
  7. Inspection and maintenance
  8. Storage and mobilization
  9. Replacement or repair of damaged components
Rather than comparing equipment price alone, contractors should evaluate the total cost of the protective system for the project and confirm that the selected system meets the required design and safety criteria.
Trench Shoring Rental vs. Buying
Renting can make sense when a contractor needs shoring for short-term or occasional projects and wants to avoid storage and long-term ownership costs.
Buying may make sense for contractors with recurring trenching work who can keep the equipment utilized across multiple projects.
Before purchasing used shoring equipment, verify its structural condition, dimensions, rated capacity, manufacturer information, repair history, and compatibility with the intended application. Damaged protective-system equipment must be evaluated for suitability before continued use.
Common Trench Shoring Problems
Common problems that can affect shoring performance include:
  1. Bent or damaged structural members
  2. Hydraulic leaks or pressure loss
  3. Damaged connections or braces
  4. Corrosion
  5. Cracked welds
  6. Improper installation
  7. Using a system outside its rated capacity
  8. Incorrect shoring configuration
  9. Soil movement behind or beneath the system
  10. Changes in groundwater or weather conditions
  11. Excessive loads near the trench edge
A protective system should not be treated as permanent once installed. Excavation conditions can change, so inspections must continue throughout the work.
Trench Shoring Best Practices
For safer and more efficient trenching, contractors should:
  1. Plan the excavation before digging.
  2. Locate underground utilities and assess nearby structures.
  3. Classify the soil and evaluate site conditions.
  4. Select a protective system appropriate for the excavation.
  5. Follow engineered designs, manufacturer instructions, or applicable tabulated data.
  6. Coordinate shoring installation with excavation progress.
  7. Keep spoil and equipment away from the trench edge.
  8. Provide safe access and egress.
  9. Inspect the trench and protective system regularly.
  10. Stop work and remove employees when hazardous conditions develop.
OSHA emphasizes pre-job planning, soil evaluation, protective-system selection, utility identification, and competent-person inspections as key parts of trenching safety.
Safety & Regulatory References
Trench excavation and protective-system requirements vary by location and project conditions. For U.S. construction projects, refer to OSHA 29 CFR 1926 Subpart P for requirements covering excavation safety, protective systems, inspections, and competent-person responsibilities. Always follow applicable local regulations, engineered designs, and manufacturer specifications.
Trench Shoring FAQs
What is trench shoring?
Trench shoring is a structural support system used to support excavation sides and help prevent cave-ins.
What are the main types of trench shoring?
Common types include timber, hydraulic, mechanical, aluminum hydraulic, and sheeting-based systems. Trench shields or trench boxes provide shielding rather than directly supporting the trench walls.
Is a trench box the same as shoring?
No. A trench box is a shielding system that protects workers within a defined area, while shoring is designed to support excavation sides and prevent cave-ins.
How deep can you dig without shoring?
Under OSHA's federal construction rules, an excavation less than 5 feet deep may qualify for an exception when a competent person determines there is no indication of a potential cave-in. Other excavations generally require an appropriate protective system unless another applicable exception applies.
Who decides what trench protection is required?
A competent person evaluates site conditions and the potential for cave-ins and helps determine the appropriate protective measures. Certain designs require a registered professional engineer.
How often should a trench be inspected?
OSHA requires inspections by a competent person before work begins, as needed during the shift, and after rainstorms or other hazard-increasing occurrences when employee exposure can reasonably be anticipated.
The right trench shoring system depends on excavation depth, soil conditions, groundwater, surrounding loads, and project requirements. Always select, install, inspect, and use protective systems according to applicable regulations, engineered designs, and manufacturer specifications.
Planning your next excavation project? Explore the equipment and resources you need to prepare your jobsite, compare suitable machines and attachments, and make informed decisions before breaking ground.
David Baca
