Cleanroom Construction: Complete Guide to ISO Standards, Costs, Design, and Build Process (2026)
3 Min read
Josh MacDonald
Josh MacDonald
Team Player, Boom & Bucket
August 25, 2025
What Is Cleanroom Construction?
Cleanroom construction is the process of designing and building controlled environments that limit airborne particles, contamination, and pollutants.
Quick answer:
Cleanroom construction uses specialized materials, airflow systems, and filtration to maintain strict cleanliness levels required in industries like pharmaceuticals and electronics.
Why Cleanroom Construction Is Important
Cleanrooms are essential for industries where contamination can affect product quality or safety.
Key Benefits:
  1. Maintains strict contamination control
  2. Ensures product quality and compliance
  3. Supports regulatory standards (pharma, medical, semiconductor)
  4. Improves process reliability
Cleanroom ISO Classifications Explained (ISO 14644)
Cleanrooms are classified based on the number of particles allowed per cubic meter of air.
Lower ISO class = cleaner environment.
Cleanroom Construction Process (Step-by-Step)
1. Define Requirements
Determine ISO classification, application, and contamination control level.
2. Design Layout
Plan zoning, airflow direction, and equipment placement.
3. Install Structural Systems
Use non-porous materials like stainless steel and sealed panels.
4. HVAC & Filtration Setup
Install HEPA/ULPA filters and airflow systems.
5. Testing & Certification
Validate cleanliness levels based on ISO standards.
Cleanroom HVAC and Airflow Requirements
Airflow is critical to cleanroom performance.
Key Components:
  1. HEPA filters (99.97% efficiency)
  2. ULPA filters (higher efficiency for stricter environments)
  3. Laminar airflow systems
  4. Positive pressure control
Proper airflow prevents contamination from entering the cleanroom.
Cleanroom Construction Cost (2026)
Costs vary widely based on size and classification:
  1. Basic cleanroom: $100 - $300 per sq ft
  2. Mid-level cleanroom: $300 - $600 per sq ft
  3. High-spec cleanroom: $600 - $1,000+ per sq ft
Example:
A 1,000 sq ft pharmaceutical cleanroom:
$300,000 - $800,000+
Modular vs Traditional Cleanroom Construction
Modular cleanrooms are becoming more popular for faster deployment.
Real-World Cleanroom Example
In a pharmaceutical facility:
  1. ISO 5 cleanroom installed
  2. HEPA filtration system integrated
  3. Positive pressure maintained
Result:
  1. Reduced contamination risk
  2. Improved compliance
  3. Higher production efficiency
Common Cleanroom Construction Mistakes
❌ Poor airflow design
❌ Incorrect material selection
❌ Inadequate sealing
❌ Ignoring ISO compliance
Even small errors can compromise the entire environment.
Cleanroom Design Best Practices
  1. Use smooth, non-porous surfaces
  2. Minimize joints and seams
  3. Maintain controlled airflow direction
  4. Implement strict access control
Industries That Use Cleanrooms
  1. Pharmaceuticals
  2. Biotechnology
  3. Semiconductor manufacturing
  4. Aerospace
  5. Medical device production
FAQ: Cleanroom Construction
What is cleanroom construction?
Cleanroom construction creates controlled environments that limit airborne contamination using filtration and airflow systems.
What is ISO 14644?
ISO 14644 is the international standard that defines cleanroom classifications based on particle concentration.
How much does a cleanroom cost?
Cleanroom construction costs range from $100 to $1,000+ per square foot depending on complexity and classification.
What industries need cleanrooms?
Industries like pharmaceuticals, electronics, and medical manufacturing require cleanrooms for contamination control.
Build precision-controlled environments with confidence.
Equip your cleanroom construction projects with the right tools, systems, and planning strategies to meet strict industry standards.
Josh MacDonald
Josh MacDonald is one of the first hires at Boom & Bucket.
