Heating and Cooling Equipment: Types, Uses & Buying Guide
Albert Demi
Albert Demi
Account Manager, Boom & Bucket
octubre 5, 2026
Heating and cooling equipment helps maintain suitable temperatures and working conditions in residential, commercial, industrial, and construction environments. Common equipment includes heaters, air conditioners, heat pumps, chillers, boilers, and portable climate-control units.
The right equipment depends on the size of the space, required heating or cooling capacity, operating environment, available power or fuel, ventilation requirements, and intended application.
What Is Heating and Cooling Equipment?
Heating and cooling equipment is designed to raise, lower, or maintain indoor and enclosed-space temperatures. Some systems provide heating or cooling separately, while others, such as heat pumps, can provide both.
For construction and industrial applications, equipment may be permanent or portable. Portable units can provide temporary temperature control during construction, maintenance, seasonal work, or other projects.
Types of Heating Equipment
Portable Heaters
Portable heaters provide temporary or localized heat and are commonly used on construction sites, workshops, warehouses, and other spaces requiring supplemental heating.
Fuel sources can include electricity, propane, natural gas, or other approved fuels. Fuel-fired heaters require appropriate ventilation and installation clearances.
Forced-Air Heaters
Forced-air heaters use a fan to distribute heated air through a space. They can quickly raise temperatures in large or partially enclosed areas and are commonly used for temporary heating applications.
Radiant Heaters
Radiant heaters transfer heat directly to people, surfaces, and objects rather than relying primarily on heating the surrounding air. They can be useful for localized heating in large or open spaces.
Electric Heaters
Electric heaters convert electrical energy into heat and are available in portable and fixed configurations. They can be useful where electrical power is available and combustion-based equipment is unsuitable.
Boilers and Hydronic Systems
Boilers heat water or another fluid that is circulated through pipes to provide heat through radiators, radiant systems, air-handling equipment, or other heat-transfer devices.
Types of Cooling Equipment
Portable Air Conditioners
Portable air conditioners provide localized cooling and can be useful where permanent air-conditioning systems are unavailable or impractical.
Air Conditioning Systems
Air-conditioning equipment removes heat from indoor air and transfers it outside. Systems may include packaged units, split systems, or other configurations depending on the application.
Evaporative Coolers
Evaporative coolers reduce air temperature by using water evaporation. Their effectiveness depends heavily on climate and humidity conditions.
Chillers
Chillers remove heat from water or another circulating fluid. They are commonly used in larger commercial and industrial cooling systems and can supply chilled water to air-handling or process equipment.
Heat Pumps
Heat pumps transfer heat rather than simply generating it. Depending on the system, they can provide both heating and cooling by reversing the direction of heat transfer.
Heating vs. Cooling Equipment Comparison
The best choice depends on the application, space, climate, available utilities, required capacity, and operating conditions.
Heating and Cooling Equipment for Construction and Industrial Applications
Construction and industrial environments can have different climate-control requirements from residential buildings.
Temporary heating may be required during cold-weather construction, equipment maintenance, concrete-related work, or work in enclosed structures. Cooling equipment can help manage heat in enclosed workspaces and provide more suitable conditions for workers and equipment.
OSHA requires appropriate ventilation when temporary heaters are used in confined spaces and specifies clearance and installation requirements for certain temporary heating devices.
For workplace heat management, OSHA also distinguishes air cooling from ventilation: air conditioning removes heat from air, while ventilation primarily moves or replaces air.
Key Heating and Cooling Equipment Specifications
When comparing equipment, consider more than the purchase price.
Important specifications can include:
  1. Heating or cooling capacity
  2. BTU/h or other capacity ratings
  3. Electrical requirements
  4. Fuel type
  5. Airflow
  6. Operating temperature range
  7. Coverage area
  8. Refrigerant type where applicable
  9. Energy-efficiency ratings
  10. Noise level
  11. Operating weight
  12. Dimensions
  13. Portability
  14. Ventilation requirements
  15. Exhaust requirements
  16. Control systems
  17. Maintenance requirements
Always compare specifications using the manufacturer's documentation and the exact model and configuration.
How to Choose the Right Heating and Cooling Equipment
Start by identifying the environment and the job requirements.
1. Determine the Application
Decide whether the equipment is needed for construction, industrial production, warehouse operations, temporary workspaces, maintenance, or another application.
2. Calculate Required Capacity
Select equipment based on the size and characteristics of the space rather than choosing solely by physical size or price. Proper sizing is important because oversized or undersized equipment can affect comfort, operating costs, and performance.
3. Check Power or Fuel Requirements
Determine whether the site has the required electrical service, fuel supply, ventilation, and connections.
4. Consider the Operating Environment
Evaluate temperature, humidity, dust, ventilation, enclosure, outdoor exposure, and available space.
5. Evaluate Portability
For temporary projects, wheels, lifting points, compact dimensions, and transportation requirements may be important.
6. Compare Operating Costs
Consider fuel or electricity consumption, maintenance, replacement parts, transportation, and expected service life.
7. Review Safety Requirements
Check manufacturer instructions and applicable workplace regulations before operating heating or cooling equipment.
Used Heating and Cooling Equipment Buying Guide
Used equipment can provide a lower initial purchase cost, but condition and maintenance history are critical.
Before buying used heating or cooling equipment, review:
  1. Manufacturer and model
  2. Model year
  3. Operating hours
  4. Capacity
  5. Previous application
  6. Maintenance records
  7. Repair history
  8. Fuel or power requirements
  9. Included accessories
  10. Operating condition
  11. Availability of replacement parts
Compare the equipment's age and operating hours with its service history. A machine with documented maintenance can be a stronger purchase candidate than equipment with fewer hours but an unknown history.
Used Heating and Cooling Equipment Inspection Checklist
Inspect used equipment before purchasing, especially when the equipment will be used continuously or in demanding environments.
General Condition
Check the frame, housing, panels, wheels, handles, mounts, and signs of corrosion or physical damage.
Heating System
Inspect burners, heat exchangers, fuel lines, controls, fans, electrical connections, and safety controls where applicable.
Cooling System
Check compressors, coils, fans, refrigerant-related components, hoses, drains, and controls.
Electrical System
Test switches, controls, wiring, displays, breakers, motors, and other electrical components.
Airflow and Ventilation
Check fans, filters, duct connections, vents, and exhaust components.
Safety Equipment
Verify guards, shutdown systems, alarms, protective devices, and other safety features.
Maintenance Records
Review service records, previous repairs, replacement components, and evidence of routine maintenance.
Operating Test
When safe and appropriate, operate the equipment long enough to identify unusual noises, leaks, vibration, overheating, poor airflow, or inconsistent temperature control.
For used heavy equipment, Boom & Bucket inspection reports can include checks of systems such as the air conditioner, heater, engine, cooling system, drivetrain, hydraulics, electrical components, and safety equipment.
Maintenance and Safety
Regular maintenance can help maintain equipment performance and identify problems before they become expensive repairs.
Common maintenance tasks include:
  1. Cleaning or replacing filters
  2. Inspecting electrical connections
  3. Checking hoses and fittings
  4. Inspecting fans and motors
  5. Checking fuel systems
  6. Cleaning coils and heat-transfer surfaces
  7. Inspecting drains
  8. Checking controls and safety devices
  9. Following manufacturer service intervals
Safety is particularly important with fuel-fired heating equipment. OSHA requires adequate fresh air and ventilation in certain applications and specifies clearance requirements for temporary heating devices.
Always follow the manufacturer's operating instructions and applicable regulations.
Expert Insights on Heating and Cooling Equipment
Choosing heating and cooling equipment requires evaluating capacity, operating environment, power or fuel requirements, ventilation, portability, maintenance needs, and total operating costs. For used equipment, buyers should also review operating hours, service history, previous applications, and overall condition.
FAQs About Heating and Cooling Equipment
What are the main types of heating equipment?
Common types include portable heaters, forced-air heaters, radiant heaters, electric heaters, furnaces, boilers, and heat pumps.
What are the main types of cooling equipment?
Common cooling equipment includes air conditioners, portable cooling units, evaporative coolers, chillers, and heat pumps.
What is HVAC equipment?
HVAC stands for heating, ventilation, and air conditioning. HVAC equipment controls temperature and may also support ventilation, humidity control, and indoor air quality.
How do I choose heating and cooling equipment?
Consider the application, space size, required capacity, climate, power or fuel availability, ventilation, portability, operating costs, and maintenance requirements.
Is used heating and cooling equipment worth buying?
Used equipment can be a practical option when its capacity, condition, maintenance history, and operating requirements match the intended application. A thorough inspection is recommended.
What should I check when buying used equipment?
Check the overall condition, capacity, engine or compressor, electrical system, fans, controls, cooling or heating components, safety systems, operating hours, and maintenance records.
How often should heating and cooling equipment be maintained?
Maintenance intervals vary by equipment type and manufacturer. Follow the service schedule for the specific model and inspect critical components regularly.
Find Used Equipment
Ready to find equipment for your next project? Compare used equipment by type, model, specifications, operating hours, condition, and price.
Explore Boom & Bucket's used equipment inventory to find machines and equipment that match your project requirements and budget.
Choosing the right heating and cooling equipment starts with understanding your application, required capacity, operating environment, and budget. Whether buying new or used, compare specifications, condition, maintenance history, safety requirements, and total ownership costs to find equipment that fits your project.
Albert Demi
Albert Demi is an Account Manager at Boom & Bucket, managing high-value construction and heavy equipment accounts with a focus on retention, growth, and tailored equipment solutions. With a strong background in sales leadership and partnerships, Albert is known for exceeding revenue targets, maintaining exceptional renewal rates, and building long-term client relationships through proactive support and industry insight.
