New Holland LS180: A Complete Guide to Specs, Features, and Buying Tips
Mike Kennedy
Mike Kennedy
Marketplace Operations Manager, Boom & Bucket
septiembre 18, 2025
If you're looking for a reliable and powerful skid steer loader, the New Holland LS180 is a great choice. Known for its robust performance, versatility, and advanced technology, the LS180 is an excellent option for various industries, including agriculture, construction, and landscaping. In this guide, we'll cover everything you need to know about the New Holland LS180, including its specs, engine, lift capacity, and where to find one for sale.
What Is a New Holland LS180?
The New Holland LS180 is a skid steer loader used for construction, landscaping, farming, loading, grading, and material-handling tasks.
How Much Can a New Holland LS180 Lift?
Published LS180.B specifications list a rated operating capacity of approximately 2,200 pounds. Capacity may vary by model and configuration.
How Much Does a New Holland LS180 Weigh?
The LS180.B has an approximate operating weight of 7,095 pounds before adding attachments or optional equipment.
What Attachments Fit a New Holland LS180?
Compatible options may include buckets, forks, augers, grapples, trenchers, breakers, brush cutters, sweepers, and snow equipment.
Is the New Holland LS180 Reliable?
A properly maintained LS180 can be reliable, but condition, service history, hydraulic performance, and previous use should be carefully inspected.
Real-World New Holland LS180 Operating Experience
The New Holland LS180 remains useful for construction, landscaping, farming, and property maintenance. Its productivity depends on machine condition, operator skill, attachment selection, and regular maintenance. A well-maintained LS180 can handle grading, loading, pallet work, debris cleanup, and material movement efficiently. Buyers should focus on hydraulic response, engine performance, control smoothness, lift-arm wear, and service history rather than relying on hours alone.
Key Features of the New Holland LS180
The New Holland LS180 is packed with features designed to make your work faster and more efficient. Built for power, stability, and ease of operation, this skid steer loader is ready to tackle tough jobs. Here are some of the standout features that make the LS180 a leading choice in its class:
Comfortable Operator Environment: The LS180 offers a spacious, ergonomic cabin that enhances operator comfort during long hours of use. The adjustable seating, intuitive controls, and excellent visibility help reduce operator fatigue.
Hydraulic System: The LS180 features a powerful hydraulic system that allows you to easily lift, push, and maneuver heavy loads.
Maneuverability: Its compact size and excellent maneuverability make it ideal for working in tight spaces without sacrificing performance.
New Holland LS180 Engine: Power and Efficiency
At the heart of the New Holland LS180 is its powerful engine. Equipped with a New Holland LS180 engine that is built for optimal performance, this machine delivers impressive horsepower and fuel efficiency.
Engine Specs: The LS180 is powered by a reliable turbocharged engine that offers around 59 horsepower, ensuring you can tackle even the most demanding tasks with ease.
Fuel Efficiency: Thanks to its advanced engine technology, the LS180 is known for fuel efficiency, helping you save on operating costs while minimizing your environmental impact.
Durability: The engine is designed for long-lasting performance, reducing the frequency of repairs and maintenance.
The New Holland LS180 engine is built to handle a variety of tasks, from lifting and digging to pushing and transporting materials. Its durability and reliability make it a top choice for those in industries requiring heavy-duty equipment.
New Holland LS180 Lift Capacity: Strong Performance for Heavy Loads
One of the key considerations when choosing a skid steer loader is its lift capacity. The New Holland LS180 lift capacity is designed to support demanding tasks such as lifting heavy loads and handling large attachments.
Rated Operating Capacity: The LS180 has a rated operating capacity of 1,800 pounds (816 kg), which is perfect for handling various types of materials, including dirt, gravel, and construction debris.
Tipping Load: With a tipping load of around 3,600 pounds (1,633 kg), the LS180 is capable of lifting and tipping large loads, making it highly efficient for construction and other heavy-duty work.
Hydraulic System: The high-performance hydraulic system enhances the lift capacity, allowing the LS180 to perform reliably under load without compromising stability.
Whether you're lifting dirt, rocks, or other materials, the New Holland LS180 provides the strength and stability you need to get the job done efficiently.
New Holland LS180 Specifications
For a clearer picture of what the New Holland LS180 has to offer, here’s a breakdown of the key New Holland LS180 specs:
Engine Power: 59 hp (44 kW)
Operating Weight: 5,000 pounds (2,268 kg)
Lift Capacity: 1,800 pounds (816 kg)
Tipping Load: 3,600 pounds (1,633 kg)
Bucket Capacity: 0.55 cubic yards (0.42 m³)
Hydraulic Flow: 20.6 gpm (78 l/min)
Dimensions: 69 inches (1,752 mm) wide, 81 inches (2,057 mm) height
Travel Speed: 6.9 mph (11.1 km/h)
These specifications highlight the New Holland LS180 as a powerful and capable skid steer loader, well-suited for a wide range of tasks, from excavation and material handling to lifting and grading.
Advantages of the New Holland LS180
There are many reasons why the New Holland LS180 is a popular choice among operators. Here are some of the top advantages:
  1. Durability: Built with high-quality materials, the LS180 can handle tough work environments, making it a great long-term investment.
  2. Fuel Efficiency: Thanks to its efficient engine, you can complete more work while using less fuel, saving money over time.
  3. Versatility: The LS180 can be equipped with various attachments, including buckets, forks, and augers, making it a versatile tool for different applications.
  4. Ease of Maintenance: The LS180 is designed for easy servicing, reducing downtime and keeping maintenance costs low.
Where to Find New Holland LS180 for Sale
If you're in the market for a New Holland LS180 for sale, you're in luck. This popular skid steer loader is available through various channels:
Authorized Dealers: The best way to buy a new LS180 is through an authorized New Holland dealership. These dealers often offer financing options, warranties, and maintenance services.
Online Marketplaces: Websites like eBay, TractorHouse, and MachineryTrader are great places to find new and used New Holland LS180 models for sale.
Used Equipment: If you're looking for a more affordable option, used New Holland LS180 loaders can be found at auctions or through dealers specializing in pre-owned equipment. Be sure to inspect the machine thoroughly and check its maintenance history before purchasing.
Boom and Bucket: Boom and Bucket is a fantastic online marketplace for buying and selling used construction equipment. They offer a wide selection of pre-owned skid steers, including the New Holland LS180. With a focus on quality and transparency, Boom and Bucket allows you to browse equipment listings, view detailed specifications, and even request financing options.
How to Buy a Used New Holland LS180
Before buying a used LS180, verify:
  1. Model and serial number
  2. Engine hours and service records
  3. Cold-start performance
  4. Hydraulic leaks or slow movement
  5. Lift-arm pins and bushings
  6. Drive response and braking
  7. Tire condition
  8. Safety interlocks
  9. Attachment plate condition
  10. Signs of welding or structural repairs
Always test the machine under load and at operating temperature. A professional inspection is recommended for remote or high-value purchases.
Common Uses of the New Holland LS180
The New Holland LS180 is versatile and capable of handling various tasks. Here are some common uses for this powerful skid steer loader:
Construction: The LS180 is ideal for moving materials, grading, and clearing debris on construction sites.
Agriculture: Farmers use the LS180 for tasks such as hauling feed, loading bales, and clearing fields.
Landscaping: With its excellent maneuverability and lift capacity, the LS180 is perfect for landscaping projects, including moving soil, rocks, and mulch.
Snow Removal: In winter, the LS180 can be fitted with snow plows and other attachments to help clear driveways and parking lots.
Its impressive specs and capabilities make the New Holland LS180 suitable for a wide range of industries and tasks.
Best Applications for the New Holland LS180
The New Holland LS180 is suitable for:
  1. Loading soil, gravel, mulch, and debris
  2. Rough grading and site preparation
  3. Pallet and material handling
  4. Farm and livestock work
  5. Landscaping and property maintenance
  6. Snow removal
  7. Trenching and drilling with compatible attachments
Its compact size makes it useful on residential sites, farms, yards, and confined construction areas.
New Holland LS180 Performance KPIs
Monitoring these metrics helps owners identify rising costs, declining performance, and maintenance needs early.
Compatible Attachments for the New Holland LS180
Common LS180 attachments include:
  1. General-purpose buckets
  2. Grapple buckets
  3. Pallet forks
  4. Augers
  5. Trenchers
  6. Hydraulic breakers
  7. Brush cutters
  8. Snow blades
  9. Sweepers
  10. Bale spears
Before purchasing an attachment, confirm coupler fit, hydraulic flow, pressure requirements, attachment weight, hose connections, and electrical controls. Physical fit alone does not guarantee proper operation
Common New Holland LS180 Problems and Troubleshooting
Slow or Weak Hydraulics
Check hydraulic fluid level, filter condition, leaks, damaged hoses, cylinder drift, and attachment flow requirements.
Hard Starting
Inspect the battery, cables, starter, fuel filters, air intake, and fuel system for air leaks.
Overheating
Clean the radiator and oil cooler, check coolant level, inspect belts, and verify fan operation.
Uneven Travel
Check tire pressure, control linkage, brakes, drive chains, pumps, and drive motors.
Electrical or Interlock Issues
Inspect fuses, relays, grounds, wiring, seat switches, and restraint-bar sensors. Never bypass safety systems.
New Holland LS180 Maintenance Tips
To improve LS180 reliability:
  1. Check engine oil, coolant, and hydraulic fluid daily.
  2. Inspect hoses, cylinders, and fittings for leaks.
  3. Clean the radiator and cooling package.
  4. Grease lift-arm and attachment pivot points.
  5. Maintain correct tire pressure.
  6. Replace filters and fluids on schedule.
  7. Test alarms, seat belts, and safety interlocks.
  8. Repair overheating or hydraulic noise promptly.
Use the correct operator's manual for the machine's exact model and serial number.
Frequently Asked Questions About the New Holland LS180
Is the LS180 the same as the LS180.B?
No. Specifications and components may differ, so always confirm the exact model and serial number.
What is the LS180 rated operating capacity?
Published LS180.B data lists approximately 2,200 pounds.
Can the LS180 run hydraulic attachments?
Yes, when the attachment matches the machine's hydraulic flow, pressure, coupler, weight, and control requirements.
Is the LS180 good for landscaping?
Yes. It can handle soil, mulch, stone, grading, cleanup, drilling, and material movement.
Is the LS180 suitable for farm work?
Yes. It can move feed, manure, pallets, bales, and other agricultural materials with suitable attachments.
What are common LS180 problems?
Common age-related concerns include hydraulic leaks, overheating, hard starting, drive issues, worn pins, and electrical faults.
How often should an LS180 be serviced?
Follow the operator's manual and shorten service intervals when working in dusty, muddy, hot, or attachment-heavy conditions.
What should buyers inspect first?
Check the serial number, cold start, hydraulics, drive system, lift arms, safety systems, tires, and maintenance records.
Can an LS180 be transported on a standard trailer?
Only when the trailer, axles, hitch, tires, and tow vehicle are rated for the machine, attachment, fuel, and securement equipment.
The New Holland LS180 is a top-performing skid steer loader with powerful features, including a reliable engine, impressive lift capacity, and versatile specifications. Whether you're in construction, agriculture, or landscaping, the LS180 offers the performance and durability you need to get the job done. If you're looking to purchase a New Holland LS180 for sale, check out authorized dealers, online listings, or used equipment options. With its solid design and exceptional performance, the New Holland LS180 is sure to be a valuable addition to your fleet.
Mike Kennedy
