Waste & Recycling: Equipment, Solutions & Best Practices
Javier Bocanegra
Javier Bocanegra
agosto 31, 2026
Effective waste management helps businesses improve efficiency, safety, sustainability, and cost control. From compactors and balers to loaders and shredders, the right equipment makes collecting, sorting, processing, and recycling materials easier.
This guide covers waste and recycling equipment, sustainable practices, safety, and used equipment buying tips to help you choose the right solutions for your operation.
What is the most sustainable way to manage waste?
Source reduction and reuse are generally the most preferred strategies, followed by recycling and composting. Energy recovery, treatment, and disposal may be appropriate when higher-value options are not feasible.
How We Evaluate Equipment
We evaluate waste and recycling equipment based on application, material type, capacity, productivity, operating environment, attachment compatibility, maintenance requirements, safety considerations, and total cost of ownership.
For used equipment, we also consider operating hours, maintenance history, wear components, hydraulic and mechanical condition, structural integrity, and overall suitability for the intended application.
Specifications can vary by manufacturer, model, configuration, and attachment. Buyers should verify technical specifications and safety requirements using manufacturer documentation and applicable regulations before purchasing or operating equipment.
This evaluation approach helps buyers focus on real-world performance and long-term value-not simply the lowest purchase price.
What Is Waste and Recycling?
Waste management is the process of reducing, collecting, sorting, processing, recovering, and disposing of materials that are no longer needed. Recycling focuses on recovering useful materials and processing them into raw materials for new products. Sustainable waste management prioritizes source reduction and reuse first, followed by recycling and composting, with energy recovery, treatment, and disposal used when higher-value options are not practical.
Waste Management vs. Recycling
Waste management is broader than recycling. It covers the entire process of handling waste, while recycling is one strategy for recovering usable materials.
A sustainable program should evaluate the entire material lifecycle, rather than treating recycling as the only solution. EPA's sustainable materials management approach considers materials from extraction and manufacturing through use, reuse, and end-of-life management.
Waste Management Hierarchy
The waste management hierarchy provides a practical framework for deciding what should happen to waste.
Most preferred
1. Source reduction and reuse
Prevent waste from being created or keep products and materials in use.
2. Recycling and composting
Recover usable materials or process appropriate organic waste.
3. Energy recovery
Recover usable energy from materials that cannot reasonably be recycled or composted.
4. Treatment and disposal
Treat or safely dispose of materials when higher-value options are not feasible.
EPA identifies source reduction as the most environmentally preferred approach and emphasizes reducing, reusing, recycling, and composting before lower-priority management methods.
Types of Waste
Different waste streams require different handling, equipment, and processing methods.
Municipal solid waste
Common household and community waste such as packaging, paper, plastics, and other discarded products.
Construction and demolition waste
Materials such as concrete, wood, metals, drywall, and other building materials. Source reduction, salvage, deconstruction, and recycling can help divert these materials from disposal.
Commercial and industrial waste
Waste generated by businesses, manufacturing facilities, warehouses, and other operations.
Organic waste
Food scraps, yard trimmings, and other biodegradable materials that may be suitable for composting or other biological processes.
Recyclable materials
Common streams include:
  1. Cardboard
  2. Paper
  3. Metals
  4. Glass
  5. Plastics
  6. Certain electronics
  7. Reusable construction materials
Important: Local regulations and recycling programs determine which materials can actually be accepted and how they must be handled.
Waste and Recycling Equipment
The right equipment can improve material handling, processing efficiency, storage, and transportation.
Common recycling and waste equipment includes:
  1. Balers - Compress recyclable materials into manageable bales.
  2. Compactors - Reduce waste volume for storage or transportation.
  3. Shredders - Reduce or process selected materials.
  4. Screens - Separate materials by size.
  5. Conveyors - Move materials between processing stages.
  6. Sorting systems - Separate materials into different waste streams.
  7. Wheel loaders - Move bulk materials around recycling and waste facilities.
  8. Skid steers - Handle materials and perform cleanup in smaller or confined areas.
  9. Excavators - Handle, sort, or process certain bulk materials with suitable attachments.
  10. Forklifts - Move pallets, bales, containers, and processed materials.
Equipment should be selected according to material type, throughput, available space, attachment requirements, operating environment, and maintenance resources.
Waste Sorting and Recycling Process
A typical recycling workflow can include:
Collection → Sorting → Processing → Material Recovery → Storage → Transportation → Remanufacturing
Sorting is critical because contamination can reduce the value or usability of recovered materials.
An efficient operation should establish:
  1. Clearly defined waste streams
  2. Appropriate collection containers
  3. Consistent sorting procedures
  4. Contamination controls
  5. Suitable processing equipment
  6. Material storage areas
  7. Reliable downstream markets
EPA notes that recycling involves collecting materials, sorting and processing them into raw materials, and using those recovered materials to manufacture new products.
How to Choose Waste and Recycling Equipment
The best machine depends on the material being handled and the work the equipment must perform.
Before purchasing, evaluate:
Material type
Determine whether you're processing cardboard, metals, plastics, construction debris, organic materials, or mixed waste.
Volume and throughput
Estimate how much material the operation handles per hour, day, or week.
Processing requirements
Consider whether materials need to be sorted, compacted, baled, shredded, screened, or simply moved.
Facility layout
Measure available operating space, loading areas, storage areas, and access routes.
Equipment compatibility
Verify attachment compatibility, hydraulic requirements, lifting capacity, and machine dimensions.
Operating costs
Consider fuel or electricity, maintenance, wear components, labor, transportation, and downtime.
The cheapest machine is not always the most economical choice. Productivity, reliability, maintenance, and expected utilization should be considered together.
Sustainable Waste Management Best Practices
Sustainable waste management starts before waste enters the waste stream.
Reduce waste at the source
Use less material, reduce packaging, improve production efficiency, and prevent unnecessary waste.
Reuse materials
Repair, reuse, remanufacture, donate, or repurpose materials whenever practical.
Improve sorting
Separate materials correctly to reduce contamination and increase recovery opportunities.
Maintain equipment
Well-maintained equipment can help reduce unexpected downtime and inefficient operation.
Track performance
Measure waste generation, recycling rates, contamination, equipment utilization, and disposal volumes.
Develop reliable recycling outlets
Identify where recovered materials will go before investing heavily in processing capacity.
EPA recommends measuring materials management practices because what is measured can be evaluated for environmental and economic improvement.
Construction Waste and Recycling
Construction companies can reduce disposal costs and material waste by incorporating waste reduction into project planning.
Practical strategies include:
  1. Order materials accurately
  2. Protect materials from damage
  3. Salvage reusable components
  4. Separate construction materials
  5. Recycle concrete and metals where appropriate
  6. Reuse lumber and other recoverable materials
  7. Plan deconstruction where practical
EPA specifically recommends source reduction, buying used and recycled products, preserving existing structures, and salvaging or reusing materials as strategies for managing construction and demolition waste.
Equipment opportunity
Depending on the operation, contractors may use wheel loaders, skid steers, excavators, forklifts, compactors, crushers, screens, and material-handling attachments to move and process recovered materials.
Recycling Equipment Costs
There is no single cost for recycling equipment because prices vary considerably by machine type, size, capacity, age, condition, configuration, and market.
When comparing equipment, calculate the total cost of ownership, including:
  1. Purchase price
  2. Financing
  3. Fuel or electricity
  4. Labor
  5. Maintenance
  6. Wear parts
  7. Repairs
  8. Transportation
  9. Downtime
  10. Expected resale value
For many operations, a used machine in good condition can provide a practical way to add capacity without the upfront cost of comparable new equipment.
New vs. Used Recycling Equipment
New equipment
Advantages:
  1. Newer components
  2. Current technology
  3. Manufacturer warranty may be available
  4. Known operating history
Used equipment
Advantages:
  1. Lower initial purchase price
  2. Potentially faster return on investment
  3. Proven operating history
  4. Access to established machine models
When buying used equipment, inspect:
  1. Engine or power system
  2. Hydraulics
  3. Structural components
  4. Wear parts
  5. Tires or tracks
  6. Electrical systems
  7. Safety guards
  8. Operating hours
  9. Maintenance records
Condition and suitability should matter more than age alone.
Waste & Recycling Equipment Safety
Waste and recycling facilities can expose workers to moving machinery, crushing hazards, unexpected startup, material handling risks, and other hazards.
OSHA specifically identifies hazards associated with balers, compactors, conveyors, forklifts, and other recycling equipment. Machine guarding and procedures for controlling hazardous energy are important safety measures.
Basic safety practices
  1. Keep machine guards in place.
  2. Train operators on specific equipment.
  3. Follow manufacturer instructions.
  4. Keep workers away from moving components.
  5. Establish lockout/tagout procedures where required.
  6. Inspect equipment before operation.
  7. Keep material piles stable.
  8. Maintain clear pedestrian and equipment routes.
  9. Never bypass safety devices.
Always follow applicable OSHA requirements, local regulations, and manufacturer safety procedures.
Waste Management Technology
Modern waste operations increasingly use technology to improve sorting, tracking, and productivity.
Potential technologies include:
  1. Automated sorting
  2. Optical sorting
  3. Material sensors
  4. Digital weighing systems
  5. Fleet telematics
  6. Equipment monitoring
  7. Route optimization
  8. Data-based waste tracking
Technology should support a clear operational goal, such as reducing contamination, increasing recovery, improving equipment utilization, or reducing downtime.
How to Improve Waste Management Efficiency
An efficient operation should focus on the entire workflow rather than purchasing equipment in isolation.
Use this process:
Measure → Identify bottlenecks → Improve sorting → Select appropriate equipment → Train operators → Maintain equipment → Track results
For example, if a facility's primary problem is material accumulation rather than processing capacity, increasing equipment size may not solve the underlying issue.
Measure:
  1. Tons or volume processed
  2. Contamination rate
  3. Equipment utilization
  4. Downtime
  5. Labor requirements
  6. Disposal volume
  7. Recovered material value
EPA's Waste Reduction Model can also be used to compare potential environmental and economic impacts of different materials-management practices.
Frequently Asked Questions
What equipment is used for recycling?
Common equipment includes balers, compactors, shredders, screens, conveyors, sorting systems, wheel loaders, skid steers, excavators, and forklifts. The right equipment depends on the material and processing requirements.
What is the difference between waste management and recycling?
Waste management covers the broader process of handling waste, while recycling is one method of recovering usable materials from the waste stream.
How can construction companies reduce waste?
Construction companies can reduce waste through accurate material planning, source reduction, salvage, reuse, deconstruction, material separation, and recycling.
Is used recycling equipment worth buying?
Used recycling equipment can provide value when its condition, capacity, maintenance history, and operating costs fit the application. A thorough inspection is important before purchasing.
How do I choose recycling equipment?
Start with material type, volume, required processing, facility space, throughput, attachment compatibility, maintenance requirements, and total cost of ownership.
The right equipment can turn a waste-management bottleneck into a more efficient workflow. Browse available used equipment on Boom & Bucket to find machines that match your material-handling, recycling, and site requirements.
Choosing the Right Waste & Recycling Solutions
Effective waste management starts with understanding what materials you handle, how much you process, and where your operation needs greater efficiency. The right combination of recycling equipment, material-handling machines, maintenance practices, and safety procedures can help reduce waste, control operating costs, and improve productivity.
Whether you need a baler, compactor, shredder, wheel loader, skid steer, excavator, or forklift, focus on equipment that matches your workload, facility, materials, and long-term operating needs. For used equipment, carefully evaluate condition, operating hours, maintenance history, specifications, and expected ownership costs before making a purchase.
Ready to Find the Right Equipment?
Turn your waste-management challenges into a more efficient operation. Explore Boom & Bucket's selection of used heavy equipment to compare machines based on your application, capacity, condition, and budget. Browse available equipment today and find the right machine to keep your waste and recycling operation moving.
Javier Bocanegra
