Concrete Crushers: Turning Waste into Value
13 Lectura mínima
Rex Walz
Rex Walz
Fleet Advisor, Boom & Bucket
enero 6, 2024
Concrete, the backbone of modern construction, holds immense potential even in its discarded form. Yet, transforming solid blocks of concrete into reusable material demands the aid of a powerful ally: the concrete crusher. In this comprehensive guide, we'll delve into the workings, types, uses, and essential considerations before investing in these machines.
What Is a Concrete Crusher?
A concrete crusher is a crushing machine designed to reduce demolished or waste concrete into smaller pieces that can be processed, reused, or recycled. Depending on the crusher type and application, concrete can be reduced to a specified size for use as recycled aggregate or other construction materials.
Concrete crushers are commonly used in demolition, construction and demolition (C&D) recycling, road projects, site clearing, and aggregate processing. Mobile crushers can process material closer to where demolition occurs, potentially reducing the need to haul concrete to a stationary plant.
Overview of Concrete Crushers
Concrete crushers are purpose-built machines designed to break down concrete into smaller, manageable pieces. They act as a pivotal solution in recycling concrete debris from demolition sites or construction projects, turning it into valuable materials for reuse. These crushers come in various sizes and types, each tailored for specific applications and efficiency.
Types of Concrete Crushers
Jaw Crushers: These robust crushers utilize powerful jaws to exert pressure, effectively breaking down concrete into smaller chunks. They excel in both primary and secondary crushing, making them versatile for various applications. Jaw crushers are commonly used in the initial stages of concrete processing due to their efficiency in reducing large blocks into manageable sizes, ready for further refinement or reuse.
Impact Crushers: Operating through impactful force, these machines pulverize concrete by forcefully striking it against hard surfaces. Their versatility allows for processing various materials apart from concrete. Impact crushers are renowned for their ability to produce uniform cubical-shaped end products and are often employed for recycling applications and in the construction of highways or railways.
Cone Crushers: Employing a cone-shaped design, these crushers work by squeezing concrete between a gyrating spindle and a concave surface. They excel in finer crushing tasks and are commonly used in the production of high-quality aggregates for concrete and asphalt. Cone crushers are ideal for projects requiring specific particle sizes and shapes for construction purposes.
Mobile Crushers: Designed for on-site crushing, these mobile units offer unparalleled flexibility and efficiency. They navigate diverse work environments and construction sites, enabling immediate processing of concrete debris. Their mobility reduces transportation costs and allows for quick adaptation to changing project requirements, making them invaluable for time-sensitive projects or in remote locations.
Working of Concrete Crushers
The functionality of concrete crushers revolves around precise methodologies tailored to break down concrete effectively. Operating in stages, these machines undertake primary and secondary crushing processes. Additionally, crushers often work in tandem with screening and separation equipment. This collaboration allows for the classification of crushed materials based on size, ensuring uniformity and suitability for different purposes. The seamless coordination between these processes optimizes the efficiency of concrete crushers, transforming solid concrete into valuable, reusable materials for construction projects or recycling purp
Primary Crushing: Concrete enters the crusher and encounters robust mechanisms that exert force to break it down into smaller, manageable pieces. Primary crushing sets the stage for further processing, reducing large concrete blocks into sizes suitable for secondary crushing or eventual use.
Secondary Crushing: Some crushers perform secondary crushing after the initial primary phase. This secondary stage further refines concrete into the desired sizes and shapes, meeting specific project requirements for construction materials or other applications.
Screening and Separation: Crushers often work alongside screens and separators. These additional components help segregate crushed materials based on size. The screening process ensures the production of uniform aggregates or separate materials for different applications, enhancing the efficiency of concrete crushers.
Benefits of Concrete Crushers
Reusing Concrete: Concrete crushers play a pivotal role in recycling concrete waste, transforming it into valuable aggregates suitable for new construction projects, road bases, or landscaping. This reuse of concrete significantly reduces the need for fresh materials, minimizing environmental impact and promoting sustainability.
Cost-Efficiency: Recycling concrete with crushers reduces disposal costs associated with waste removal. Additionally, it curtails expenses linked to purchasing new materials, fostering more cost-effective and sustainable construction practices while aiding in managing project budgets effectively.
Environmental Impact: By repurposing concrete, crushers contribute to a considerable reduction in the environmental footprint associated with mining and manufacturing new construction materials. This sustainable approach aligns with eco-friendly construction practices, supporting a greener future.
Elevate Offseason & Rainy-Day Efficiency: Make the most of downtime or adverse weather conditions by embracing concrete crushing. Stockpiling concrete during peak seasons facilitates off-season processing, ensuring continuous productivity. Harness nature's dust suppression during crushing, allowing work even when weather poses limitations.
Efficient Morning Operations: Concrete crushing affords you the luxury of maintaining a ready-to-use aggregate stockpile. Pre-loading dump trucks the night before streamlines morning operations, giving you a head start on the day's tasks and reducing lag time.
Seize Control of Material Quality: Taking charge of recycled concrete quality starts from the source. By managing and separating raw materials through in-house concrete crushing, you mitigate issues arising from inconsistent material quality, safeguarding your reputation and satisfying client demands.
Freedom from External Schedules: Embrace autonomy by reducing reliance on quarry hours, recycle yard constraints, or external contractors' schedules. Independent concrete crushing allows for extended working hours, minimizing delays caused by queues or external dependencies.
Unlock Additional Revenue Avenues: Apart from selling recycled aggregates, having your own crushed concrete opens doors to selling trucking services. Offering pick-up services bolsters your trucking business, capitalizing on every aspect of your operations.
Maintain a Pristine Yard: Regular material processing through concrete crushing ensures a clutter-free yard. Avoid accumulating stockpiles that not only occupy valuable space but also pose safety hazards. Maintaining a clean yard showcases professionalism and operational efficiency.
Profit from Salvaged Rebar: Concrete crushing doesn't just yield crushed material; it liberates substantial amounts of rebar. Recycling this rebar at scrap metal collectors brings in unexpected additional income. Moreover, using hydraulic magnet excavator attachments helps collect all ferrous materials, optimizing your site's cleanliness and potential earnings.
Embracing concrete crushing isn't merely about material processing; it's a strategic move that empowers your business, offering a multitude of benefits beyond the surface.
Things You Should Know Before Buying Concrete Crushers
When selecting the ideal concrete crusher to meet your aggregate production and construction needs, understanding which type aligns best with your requirements is crucial. In most instances, the primary choices revolve around two main crusher types: jaw and cone crushers. Generally, jaw crushers excel in primary crushing tasks, whereas cone crushers are more suitable for secondary and tertiary crushing phases.
Determining the appropriate concrete crusher involves considering specific factors:
Capacity and Output: Assess the crusher's capacity to ensure it aligns with the required processing volume and desired output. Understanding the machine's capabilities in handling different material sizes aids in choosing the most suitable crusher for the project.
Mobility and Portability: Determine whether a stationary or mobile crusher best suits your operational needs and site-specific requirements. Mobile crushers offer flexibility in terms of on-site operations and adaptability to different job sites.
Maintenance and Operating Costs: Consider maintenance needs and associated operating expenses to estimate the long-term feasibility of owning and operating a concrete crusher. Regular maintenance ensures optimal performance and longevity of the equipment.
Quality and Durability: Opt for crushers from reputable manufacturers known for quality and durability. Investing in robust equipment ensures prolonged and efficient use, minimizing downtime and maintenance costs while maximizing productivity and reliability. Choosing high-quality machinery translates to long-term benefits and efficiency in operations.
Best Concrete Crusher for Your Business
Selecting the ideal concrete crusher for your business involves a nuanced understanding of your operational stage and project requirements.
Beginners: For beginners venturing into concrete crushing, a small jaw crusher might serve as an optimal starting point. These compact machines offer ease of use and maintenance, catering to initial crushing needs without overwhelming complexity. They're suitable for smaller-scale projects, allowing newcomers to grasp the basics of concrete processing.
Intermediate operators: Intermediate operators seeking versatility and scalability often find mid-sized jaw crushers a valuable asset. These machines strike a balance between performance and manageable size, catering to expanding operational needs. With enhanced power and capacity compared to smaller models, mid-sized jaw crushers accommodate a broader range of projects, facilitating gradual progression in concrete processing expertise.
 Impact Crushers: For those exploring advanced options, impact crushers stand out. Their ability to pulverize concrete via impactful force makes them ideal for comprehensive material processing. Impact crushers excel in handling diverse materials beyond concrete, offering high-capacity crushing for larger-scale projects. However, their intricate mechanisms may require a more experienced operator's understanding to optimize performance.
The best concrete crusher for your business depends on your familiarity with the process, project scale, and versatility required. Beginners might benefit from small jaw crushers' simplicity, while intermediate users can explore mid-sized jaw crushers for expanded capabilities. Advanced operators could consider impact crushers for comprehensive material processing, provided they possess the necessary expertise to leverage their advanced functionalities. Ultimately, aligning the crusher choice with your operational stage and project demands ensures optimal efficiency and growth in your concrete processing endeavors.
How Concrete Crushing Works
Concrete crushing generally follows these steps:
  1. Material preparation: Remove or separate large contaminants and prepare the demolition material.
  2. Feeding: An excavator or loader places concrete into the crusher's feed hopper.
  3. Primary crushing: The crusher reduces large concrete pieces to smaller material.
  4. Screening: Screens separate material according to required size.
  5. Secondary crushing: Additional crushing may be used when a smaller or more consistent product is required.
  6. Metal separation: Magnets or other separation equipment can remove ferrous metal such as rebar.
  7. Stockpiling: Finished recycled aggregate is separated for its intended application.
The exact process depends on the material, crusher configuration, desired product, and whether screening and separation are integrated into the plant. Some modern mobile systems combine crushing, screening, and material separation.
Concrete Recycling & Recycled Aggregate Uses
Crushed concrete can be processed into recycled aggregate for suitable construction applications. Potential uses include:
  1. Road base and subbase
  2. Fill material
  3. Pavement-related applications
  4. Drainage applications
  5. Construction-site access roads
  6. Other aggregate uses permitted by project specifications and local requirements
The quality and suitability of recycled concrete depend on the original material, contamination, processing method, particle size, and required application.
Before using recycled aggregate in structural or specification-controlled work, verify applicable project requirements and local standards.
Rebar, Contaminants & Material Preparation
Demolished concrete may contain rebar, wire, wood, plastics, soil, asphalt, and other contaminants. Proper material preparation can improve crusher performance and recycled-product quality.
Before crushing:
  1. Remove oversized non-concrete material.
  2. Separate visible contaminants where practical.
  3. Manage rebar and other metal through appropriate cutting or separation methods.
  4. Check the crusher's feed-size limitations.
  5. Use magnets or other separation equipment where appropriate.
  6. Prevent excessive soil or waste material from entering the processing stream.
Rebar can create operational challenges and should be managed according to the crusher manufacturer's recommendations. Modern recycling plants may incorporate magnetic separation specifically for metal removal. (metso.com)
Concrete Crusher Costs & Operating Expenses
Concrete crusher costs vary widely based on crusher type, capacity, size, mobility, age, condition, power system, configuration, and included equipment.
Consider these ownership and operating costs:
  1. Purchase price
  2. Financing
  3. Fuel or electricity
  4. Wear parts
  5. Jaw plates, blow bars, liners, or other crushing components
  6. Screen media
  7. Belts and bearings
  8. Hydraulic and engine maintenance
  9. Labor
  10. Transportation
  11. Dust-control equipment
  12. Downtime
  13. Repairs
  14. Resale value
For a used crusher, the condition of major wear components can have a significant effect on the machine's actual acquisition cost.
Evaluate total cost of ownership, not simply the advertised purchase price.
Concrete Crusher Maintenance & Wear Parts
Regular maintenance helps protect crusher performance and identify wear before it causes unexpected downtime.
Inspect and maintain:
  1. Jaw plates or impact wear components
  2. Liners and wear plates
  3. Bearings
  4. Belts and conveyors
  5. Hydraulic systems
  6. Engine and cooling system
  7. Feed hopper
  8. Screens
  9. Magnets and separation equipment
  10. Fasteners and structural components
  11. Lubrication points
Monitor wear components against the manufacturer's specifications and replace them before excessive wear affects other components or product quality.
Follow the manufacturer's maintenance schedule, lubrication requirements, inspection procedures, and replacement specifications.
Concrete Crusher Safety & Dust Control
Concrete crushing can generate respirable crystalline silica dust. OSHA identifies crushing machines as a source of silica exposure and recommends engineering controls such as water sprays or mists at points where dust is generated. Operator isolation can also be required under applicable construction requirements. (osha.gov)
Basic safety practices include:
  1. Follow the manufacturer's operating and maintenance procedures.
  2. Keep workers away from moving crusher components.
  3. Use appropriate guarding and access controls.
  4. Establish safe procedures for clearing blockages.
  5. Never reach into a crusher while components can move.
  6. Control dust using appropriate engineering controls.
  7. Inspect hoses, conveyors, guards, and structural components.
  8. Use appropriate PPE based on the hazards and applicable requirements.
  9. Follow applicable OSHA, local, and site-specific safety requirements.
Dust-control requirements can vary by jurisdiction and application, so consult the applicable regulations and safety plan.
Concrete Crusher FAQs
What is a concrete crusher?
A concrete crusher is a machine that breaks demolished or waste concrete into smaller pieces for recycling, reuse, or further processing.
What are the main types of concrete crushers?
Common types include jaw crushers, impact crushers, cone crushers, and mobile crushers. Each is suited to different material, output, and jobsite requirements.
How does a concrete crusher work?
Concrete is fed into the crusher for primary size reduction. Additional crushing, screening, and separation can produce the required recycled material size.
What are concrete crushers used for?
Concrete crushers are commonly used in demolition, construction, recycling, road projects, and aggregate processing.
What is the difference between jaw and impact crushers?
Jaw crushers use compression to break concrete, while impact crushers use impact forces. The right choice depends on the material and desired output.
Are mobile concrete crushers useful?
Yes. Mobile crushers can process concrete closer to the demolition or construction site, potentially reducing material-hauling requirements.
Can crushed concrete be reused?
Yes. Processed concrete can be used as recycled aggregate for suitable applications such as road base, fill, and other construction uses, subject to project specifications.
What should I consider before buying a concrete crusher?
Consider crusher type, capacity, feed size, desired output, mobility, maintenance requirements, operating costs, condition, and your specific application.
Are used concrete crushers worth considering?
A used crusher can reduce the initial purchase cost, but inspect its crushing components, wear parts, hydraulics, engine, structure, service history, and operating condition before buying.
Final Thoughts
Concrete crushers are a precious tool that transforms discarded concrete into invaluable construction material. These machines, diverse in types and functionalities, epitomize sustainability and efficiency. Understanding their operations, from primary to secondary crushing stages, and their collaboration with screening equipment illuminates their transformative potential. Embracing concrete crushers isn't merely a material processing choice; it's a strategic leap toward business empowerment. It offers an array of benefits, from environmental sustainability and cost-efficiency to increased operational autonomy and additional revenue streams. Before investing in these machines, factors like capacity, mobility, maintenance, and quality stand as pivotal considerations, paving the way for enhanced operations and lasting efficiency in construction endeavors.
Rex Walz
