Best Metal Building Guide: Types, Costs, Kits & Pros and Cons
Josh MacDonald
Josh MacDonald
Team Player, Boom & Bucket
octubre 22, 2025
Metal buildings have become one of the most popular construction options for garages, warehouses, workshops, agricultural structures, and commercial facilities. Thanks to their durability, affordability, and fast installation, many contractors and property owners now choose steel buildings over traditional wood structures.
But with so many options available, choosing the best metal building for your project can be challenging.
In this guide, we’ll explain everything you need to know, including:
  1. What metal buildings are
  2. Different types of metal buildings
  3. Metal building kits vs custom steel structures
  4. Metal building cost per square foot
  5. Pros and cons of steel buildings
  6. How to choose the best metal building for your needs
By understanding these factors, you can make a smarter decision when planning your next construction project.
What Is the Best Metal Building?
The best metal building is a steel structure designed for strength, durability, and fast construction. Metal buildings are widely used for garages, warehouses, barns, and workshops because they are affordable, weather-resistant, and require minimal maintenance.
Steel buildings are typically made from prefabricated components that can be quickly assembled on-site, reducing construction time and labor costs.
Types of Metal Buildings
There are several types of metal buildings available depending on the structure’s purpose and design.
Rigid Frame Metal Buildings
Rigid frame buildings are one of the most common steel building types used in commercial and industrial projects.
They feature strong steel columns and beams that support large open spaces without interior support columns.
Common uses include:
  1. warehouses
  2. distribution centers
  3. aircraft hangars
  4. large workshops
These structures provide excellent durability and flexibility for large facilities.
Steel Arch Buildings
Steel arch buildings use curved metal panels to form a self-supporting structure.
Advantages include:
  1. simple construction
  2. lower material costs
  3. strong resistance to wind and snow
These buildings are often used for:
  1. storage facilities
  2. agricultural buildings
  3. equipment shelters
Quonset Hut Buildings
Quonset huts are a type of arch-style steel building known for their semicircular shape.
They are often used for:
  1. military storage buildings
  2. farm equipment storage
  3. workshops
Quonset buildings are affordable and easy to install.
Tube Steel Buildings
Tube steel buildings use square steel tubing for the frame rather than large steel beams.
These buildings are commonly used for:
  1. residential garages
  2. small workshops
  3. storage buildings
They are often available as metal building kits.
Metal Building Kits vs Custom Steel Buildings
When choosing the best metal building, you will often decide between metal building kits and custom engineered steel buildings.
Metal Building Kits
Metal building kits are prefabricated structures that come with all the components needed for assembly.
Benefits include:
  1. lower costs
  2. faster installation
  3. DIY-friendly construction
They are commonly used for garages, barns, and small workshops.
Custom steel buildings are engineered specifically for a project.
Advantages include:
  1. larger structural spans
  2. customized layouts
  3. higher load capacity
These buildings are often used for commercial facilities or warehouses.
Metal Building Cost per Square Foot
Metal building prices vary depending on size, materials, and design complexity.
Below is a general cost estimate.
Additional costs may include:
  1. site preparation
  2. foundation construction
  3. insulation
  4. electrical installation
  5. interior finishing
Metal Building Cost by Size
Building size significantly affects the overall project cost.
Larger buildings often have lower cost per square foot due to material efficiency.
Common Uses for Metal Buildings
Metal buildings are used across many industries because of their strength and flexibility.
Agricultural Buildings
Farmers frequently use steel buildings for:
  1. barns
  2. livestock shelters
  3. equipment storage
  4. hay storage
Steel buildings are durable and resistant to pests and weather damage.
Warehouses
Warehouses often use steel buildings because they allow for large open interior spaces.
Benefits include:
  1. high ceilings
  2. clear-span designs
  3. strong structural support
Residential Garages
Metal building kits are popular for garages and workshops.
These structures are affordable and can be installed quickly.
Aircraft Hangars
Large steel buildings are commonly used for aircraft hangars because they provide wide, unobstructed spaces.
Pros of Metal Buildings
Metal buildings offer several advantages compared to traditional construction.
Durability
Steel structures are highly resistant to:
  1. fire
  2. termites
  3. rot
  4. extreme weather
Faster Construction
Because many components are prefabricated, metal buildings can be assembled quickly.
This reduces labor costs and construction time.
Low Maintenance
Steel buildings require less maintenance compared to wood structures.
They do not warp, crack, or attract pests.
Energy Efficiency
Many modern metal buildings include insulation systems that improve energy efficiency.
Cons of Metal Buildings
Despite their benefits, metal buildings also have a few drawbacks.
Upfront Cost
Some high-quality steel structures can require a larger initial investment.
Limited Customization
Some prefab metal building kits offer fewer design options compared to traditional construction.
Insulation Requirements
Without proper insulation, metal buildings can experience temperature fluctuations.
Equipment Used in Metal Building Construction
Several types of construction equipment are used during steel building installation.
Common equipment includes:
  1. cranes for lifting steel beams
  2. boom lifts for high installation work
  3. forklifts for moving materials
  4. concrete mixers for foundation work
Using the right equipment improves construction speed and safety.
How to Choose the Best Metal Building
Choosing the best metal building depends on several factors.
Project Purpose
Determine whether the building will be used for storage, commercial use, or agriculture.
Building Size
Consider the required floor space and future expansion needs.
Budget
Set a budget that includes construction costs, materials, and equipment.
Climate Conditions
Buildings located in areas with heavy snow or strong winds require stronger structural designs.
Local Building Codes
Ensure the metal building design meets local construction regulations.
Future Trends in Metal Buildings
Steel building technology continues to evolve.
Emerging trends include:
Energy-Efficient Steel Buildings
Improved insulation and reflective roofing systems help reduce energy consumption.
Sustainable Steel Construction
Many metal buildings use recyclable materials and environmentally friendly construction methods.
Smart Building Technology
Modern steel structures increasingly incorporate sensors and automated systems for energy management and monitoring.
Frequently Asked Questions
How much does a metal building cost per square foot?
Metal building kits typically cost $10 to $25 per square foot, while fully installed steel buildings may cost $30 to $60 or more per square foot.
What is the best metal building for a garage?
Tube steel buildings and prefab metal building kits are common choices for residential garages.
How long do metal buildings last?
Most steel buildings last 40 to 70 years or more with proper maintenance.
Are metal buildings cheaper than wood buildings?
In many cases, metal buildings are cheaper because they require less maintenance and faster construction.
Final Thoughts
Metal buildings offer a durable, affordable, and flexible construction solution for a wide range of applications. Whether used for warehouses, garages, barns, or commercial facilities, steel structures provide long-lasting performance with minimal maintenance.
By understanding the different metal building types, costs, and benefits, property owners and contractors can choose the best metal building for their project.
As construction technology continues to advance, metal buildings will remain one of the most efficient and reliable building solutions available.
Planning to build a workshop or warehouse?
Browse Boom & Bucket’s marketplace to find excavators, loaders, and construction equipment for your building project.
Josh MacDonald
Josh MacDonald is one of the first hires at Boom & Bucket.
